Looking for a high temp pipe coupling
muncybob
Not audio related at all, but can anybody point me to a 6" diameter fernco type coupling that can withstand 500 degrees F?
Yep, my name really is Bob.
500!?! Dear God man, what are you up to??
To answer your question, look for a silicone coupler ment for automotive intake piping. There are a few companies that will build you one to spec, though 6" might be a bit pricey. -
Don't want to get too pricey. It's to connect 2 exhaust pipes out of my boiler. The seam is currently sealed with RTV silicone but I wanted an easier/less messy connection. I doubt the pipes will ever get to 500(typical temps are low 300's) but that would be a safeguard in the event a fire starts in the pipes.Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Oh that's easy!!! Use fire rope. Small bead of copper seal on the inside and outside edge of the rope for a gap seal between surfaces and slide together. The rope is flexible and good for over 2500*
High temp pipe coupling ?? Is that what they call it now a days ??
In my day, we called them Trojans, 50 cents at any truck stop bathroom. Choose your style/size and color. Options baby....options...lolHT SYSTEM-
lsi 9's -
Got a feeling it won't cover the girth Tony.Yep, my name really is Bob.
