Repair or replace RTA12s
I have a pair of RTA12 that I've had since around 1979. Thought tweeter had blown. They're the top hat drivers, so I switched them, changed fuse, still only mids and bass, no tweetage. Replaced tweeter with new one from ebay. No tweetage. Question is whether to repair, by DHS Speaker Service, which I favor or buy a pair of Polk Audio LSiM 707. Equipment is Hafler 220 and 100 pre-amp, Rega Planar II w/ Orotofon blue and Yamaha CD-C600BL 5-Disc CD? Please share you views. I'm in Hawaii so cannot demo the LSiM 707s here.
  • FestYboyFestYboy Posts: 2,777
    Verify the poly switch is open before condemning the tweet.
  • pitdogg2pitdogg2 Posts: 10,839
    FestYboy wrote: »
    Silly boy he states he changed the fuse therefore there is no polyswitch >:) :p
    I'd also clean the fuse holder very well and verify that the wiring to the fuse block had not corroded so much that it can't pass a signal. It's been known to happen
  • codycatalistcodycatalist Posts: 1,621
    Repair is my vote.
    Living room
    Mains: Paradigm 90P
    Lows: Velodyne CHT12, Pioneer SW-8Mk2
    Power: Marantz SR7000
    Tv: Samsung UHD 55' Curved 4k
    2 Channel Den
    Mains: SDA2B Upgraded XOs and Binding Posts
    Pre: Denon PRA-1200
    Power: Adcom GFA-545
    TT: Pioneer PL510
    Tv: Samsung UHD 55' 4K
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Little dot 1+/GE JAN 5654w
    Closet of Dreams:
    Harman Kardon AVR130
    Yamaha HTR5590
    Polk RTA11TL
    Polk TSI200s
    New Large Advents 25th Anniversary Edition
    Bravo V2/RCA Clear top Conn branded 12AU7
    Yamaha AV-34
    edited October 2017
    Missed that! My bad. That's what happens when you skim...
    But I'm with Cody, fix 'em
  • FaustinFaustin Posts: 750
    Fix them.
  • Easy RunninEasy Runnin Posts: 404
    edited October 2017
    Blown resistor?
    HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
    Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
    2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
    Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
    BR - Yamaha CR800/Polk monitor 5
    Blown resistor?
    Very well could be, but I think that would be very visible. OP take a picture and post it. We might be able to spot something.
  • pitdogg2 wrote: »
    Will do this tomorrow. Thanks!
  • Well, I went over the mechanical issues one more time. Visually, nothing looked out of place, but I wasn't sure the solder had flowed on the tweeter hot lead. Resoldered tweeter wires with hot iron and good flow. Cleaned fuse and fuse holder with wire brush; sprayed with a dab of CRC. Resoldered fuse holder wires as they looked a bit corroded. Held breath, crossed fingers and plugged in. Put on second Traffic album. Kabaaam! Tweetage restored. Pays to go slowly and carefully. I think it was most likely the hot wire to the tweeter which was on but looked like a cold joint. Have to say, Dave at DHS was very helpful and, when I only have one tuition to pay, I may have him upgrade them with new caps and resistors. For now, it's 1979 all over again, baby! Thanks for all the responses. I truly appreciate them.
    That's great to hear. I would of crimped gold plated faston to the wires instead of soldering to the tweeter. Just my personal preference.
    Great job tracking it down
  • la2vegasla2vegas Posts: 2,799
    Good to hear you got them hummin' again. Stick around the forum a lot of good information is constantly flowing around here from some aok guys. Well at least some of us. o:)
    2.3TL, 3.1TL, SDA 2B, SDA II, 7B, 7C, 7 series 2, 10B, 5JR+, 5JR, 5A, 4.5, 4, RTA 11T X2 pairs, RTA 8T, LSI9, LSI7, RTI A7, RTI A3, CSI A4, CSI A6, F/XI A4, RTI4. That's all for now.
  • pitdogg2 wrote: »
    Would have been a good solution if I had the faston connectors, but did not think of it beforehand. Thanks.
Howdy, Stranger!
