Gold plated, removable bridging bars
ultrasoudproductions
Hello group. I purchased a set of RTi70 speakers, but I am missing a Gold plated, removable bridging bar on one of them. I have spent sometime but have come empty trying to find one. Can somebody tell me the actual Polk name or Polk part # and where to find one. I am OK if there is a generic replacement. I have temporarily solved the issue by putting a piece of speaker cable. I would think that speaker value is somewhat lowered by having the wire instead of the bridging bar or am I mistaken?
Replace them with HIGH quality speaker cable. Stock jumper plates leave a lot to be desired.Political Correctness'.........defined
President of Club Polk -
Here's mine...
Thanks for the input F1nut. -
Thanks for the input decal. -
ken brydson wrote: »Here's mine...
Thanks for the input ken brydson. -
I was looking to make my own speaker cables.
1. Design - Is there an optimum design? I was thinking having a banana plug at the receiver end, twisting together the speaker end to a 6 inch piece and crimping a spade to the twisted end and to the other remaining end of the 6 inch cable.
2. Banana plug - Is there a mid grade banana plug you would recommend?
3. SpadeIs - Is there a mid grade you would recommend?
4. Speaker wireIs - Is there a mid speaker wire and gauge you would recommend?
5. Is there a mid grade Jacket you would recommend?
6. Length - Is there a length one should not exceed?
7. Is there any other factors to consider?
Your plan sounds good. Just make sure the 6" will be enough. Most any good quality banana will work, but I'd suggest going with a banana plug made from copper. Same with the spades. To give you some info on jumpers, please take a look at our Bravo Bi-Wire jumpers. If you want to make your own and save a bit of $, we can put together a kit so you can DIY them. If you want, PM me. I'll be glad to help you with any questions. As a Club polk member, we give you a 10% discount tooSunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
txcoastal1 wrote: »
The best -
@ultrasoudproductions I echo what the others have said about Doug. He helped me out very affordably with some great speaker wire that he customized to match my spring-type speaker connections.
Thanks for the kind words guysSunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
Doug does great work. Hopefully I'm appending a photo of some jumpers Doug made for me from six inches of my speaker cables. Its advisable to use the same wire in your jumpers as your speaker cables. As F1Nut said, use high quality cable. Doug also reterminated my speaker cables shown in the photo with some really nice Furutech ends. Talk to Doug and he'll set you up however you choose to go.
https://us.v-cdn.net/5021930/uploads/editor/xp/85pnqyfy8g75.jpg -
Doug is my LSAF morning coffee buddy.
He's good people. -
https://us.v-cdn.net/5021930/uploads/editor/xp/85pnqyfy8g75.jpgSunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
Doug, of course you may use that photo. Regards. -Don
I agree with the group. Doug and his cables are excellent. I have a complete system of them from XLR to RCA to Speaker.
You can’t go wrong with his works or experience.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Silver 4+ Interconnect Cables, AudioQuest Niagara 7000 w/Dragon and Hurricane Power Cables -
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
