SDA mods needed
kwarren122
So I've had a pair of sda 1's for ages and I noticed a driver rattling and figured its obvious the y need a little work. I understand there are mods to improve the sda's and its not something I want to tackle so Im wondering if there maybe someone fairly close to Atlanta ,Ga. that is able to do this for me?
Thanx in advance
Thanx in advance
A rattling driver could be as simple as loose mounting screws. It could also be a damaged spider or shifted magnet causing voice coil rubbing. If either of the later it's time for a new driver.
For crossover mods talk to member Westmassguy.Political Correctness'.........defined
President of Club Polk -
Ok, thank you so much
Yes he does, but he doesn't mod those speakers.Political Correctness'.........defined
If you'd like another ear on it, I'm in metro Atlanta as well. Might help you determine if it's a driver that needs replacing as I've had a few that did.Expect that there will be bumps in the road. Choose to not let them rattle you.
Boston - CR7, CR6s, CR4s.
Thompson Adventures, Inc. -
....Political Correctness'.........defined
