Powered subwoofer pulsing sounds .PSW110
My subwoofer has a pulsating sound, I have tryed everything including unplugged it from the amp and plugged it into a separate power source and it still has post a popping noise. I have cut all the power off in the house and ran one circuit at a time and it still has a popping noise.
The sub is only 3years old. It is a great sub with excellent base response until now.
  • KennethSwaugerKennethSwauger Moderator Posts: 6,617
    Hello,
    In all likelihood there's a problem with the bass amplifier. Do you live in the U.S.?
    "And the house you live in will never fall down
    If you pity the stranger who stands at your gate" G.Lightfoot
  • Hello,
  • Yes I do !
  • Maybe you're listening to rap. Sometimes that'll cause an irritating pulsing sound.
    Polk SDA SRS 1
    Yamaha M-65 (2x, bi-amped)
    Pioneer Elite SC-99
    Oppo UDP-203
    Polk CS350 center
    Polk MC-60 4x Atmos
    Polk AB700 side surround
    Hello,
    In that case telephone Polk at: 1-800-377-7655 select option 1 and have the serial number and exact date of purchase handy when you call. Polk will be able to work with you to solve the problem.
    Cheers, Ken
  • Thank you for for your help.
Howdy, Stranger!
