Rta12-c schematic?
I'd like to recap mine and I need a list of the caps needed please. I notice the 12b is listed in the schematic thread but not the c, are they the same?
Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier
    pitdogg2 Posts: 24,576
    I don't get this you have the speakers right? Why not look at the crossover and BAM you have the values of the caps and resistors needed....
  • Mr. Sharpe
    Mr. Sharpe Posts: 1,354
    Yes I do, but experience tells me the yellow caps don't have uf values written on them do they?
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    I'm not seeing values written on the yellow ones unless they're covered up. I can plainly see the inner caps (27uf) no sweat and resistor and all resistors on the top board, some of the caps I can't see, I don't want to start taking them off because then I won't have speakers to listen to while waiting on cap deliveries
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
    does the cap have ANY writing on it what so ever you can see? if so take a picture we will tell you. it also could be under the cap against the board. It will have a value somewhere. I promise.
    Well you could take it off and put back on I have done that a bunch of times.
  • Mr. Sharpe
    There's one of He yellow ones that has 4.4j 100v
    Others are more 27's and a 5.5uf. You were right it isn't rocket science:) but the 4.4j I'm confused on. bqrrpdlxlgi1.jpgglaeank4rsow.jpg
    Once the yellow ones are cleared up I think they're film caps right? Is the blue something special? I don't want to replace any of them and mess up the speakers or anything
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
    F1nut Posts: 49,801
    The yellow caps are mylar, the blue is an electrolytic. Nothing special about any of them.
    The value is 4.4 uF, J is a code for the +/- tolerance.
    As long as you've been here I'm surprised you don't know this stuff.
  • Faustin
    Faustin Posts: 1,149
    I believe the 12b revised schematic is the correct one for the 12c. The revised has a poly switch instead of a fuse for the tweeter.
  • Mr. Sharpe
    I didn't know what the J was for, my old cv's had three of those and didn't know those were uf values
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
    keep in mind that the new film caps will be much bigger. you will need to be creative.
  • Mr. Sharpe
    Haha yeah I know, I saw where someone on here used sonicaps for his rta12 sprakers and he had to use two caps for the 5.5uf, I mean I'm cool with doing that but I think his upgrade cost something like $300 and that's quite a bit more than I'll spend. I still have several Dayton caps left from when I was going to recap my jbl speakers and I'm thinking I may use this but not sure yet.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    Anyway so sonicaps are probably not happening on Thai upgrade what other brand makes a good cap would you recommend besides clarity of course unless they have a "cheap skate" series:) stolen, Dayton I know Mundorf is highly regarded and jantzen
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Faustin
    If you don't want to spend the money for all Sonicaps, I would recommend going with a Sonicap Gen 1 or Clarity ESA for the high pass and then use the lesser expensive brand for the low pass. That is what I did on my 12's and once everything burned in they sounded fantastic.
  • Mr. Sharpe
    Okay I'll look into it
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    I have a question about the safety switch on top, looking at the schematic I wanna say it's a 3/4a fast blow? And what about thesejjmjntxih4eu.jpg
    What are they and will they need replacing?
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
    Looks like 750pf silver mica cap. If so those are used as bypass cap. They get tossed in most cases. You may need to use a jumper in the circuit. ATM I'm not positive. I do not have access to the schematic.
  • Mr. Sharpe
    Okay, I don't mind using a jumper as long as these aren't needed. I saw mica on the schematic and had never heard of that
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
    Like i said I'm not positive you will need a jumper. With better caps those are not needed.
  • Mr. Sharpe
    Good I'll toss em then. I'm gonna dish out for the sonicaps on the top may as well, I do have one more question then I'll leave you alone, I'm getting most items from soniccraft and it doesn't look like they carry safety switches, I'm guessing there aren't any alternatives for these huh?
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
    edited October 2017
    Why on earth would you want them? They're a problem, stick a .5 ohm 12 watt mills resistor in its place and feed the speakers good amplification.
  • westmassguy
    westmassguy Posts: 6,850
    Mr. Sharpe wrote: »
    Good heavens NO. Do not jumper them, just remove them. They're no longer needed with quality Metalized Polypropylene Capacitors
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Mr. Sharpe
    They have 300 watts and I was just askin sheesh
    Mr. Sharpe wrote: »
    Simple enough
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    So after doing some reading in some old threads am I to understand the "5.5uf" is a 55uf capacitor? I'm not at home right now so can't look... dear oh dear hahaha think I almost screwed up ordering caps to make the 5.5 value haha yikes
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    I guess the people at work were right, I am blind
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • westmassguy
    2 X 27uf will do nicely
  • Mr. Sharpe
    I gotcha thanks to all. Due to budget constraints I think I'll end up using daytons, I can't afford all of those sonicap 27's
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    I've put in all the Dayton 27uf caps onto the low end side of the speakers, I figure since I already purchased the 4.4uf sonicaps I'll be getting four 27uf sonicaps for the high end. I'll upload progress all in one comment since it's been a while since posting here. Should be within the week maybe.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
