Pressure Washer Reccomendations
kevhed72
I need a decent strength one to wash a house once a year. There is a walk out basement so one side of the house is 3 stories. Will a Harbor Freight model do....or is this a mistake and just pony up cash for a quality one??
I've had the HF 2500 PSI model for two years washing house, drive, sidewalks, pool deck and tiled roof multiple times annually. Only issue has been a rolled O-ring in the wand valve which was easy to replace. I also got the 3-year extended warranty (bring it back for any/no reason, sans gas, and get a new one) with the purchase and it all was still appreciably less than a "name brand". Hope that helps.
https://www.mitm.com/pressure-washers/CM-1400-1MEH/378
Look no further than a Mi ti-M this is the one I have, does the house patio Decks can wash vehicles does everything shy of a industrial one quality made in Iowa.Home Theater
Polk Audio Boom Swimmer, Polk Audio Urchin -
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
I've had good luck with my electric Sun Joe. You can get them on Amazon.
My only dog in this is gas. Mine had a Honda motor worked great. Just be sure to put the lube/anti freeze anti rust stuff in at the end of the season
