Help me choose a tubed integrated
So I have the GoldenEar Triton 2's. They are 91db efficiency and a powered bass section so I would think they are fairly easy to drive. I'm looking to move from my current setup to a tubed integrated amp.
My budget would be around $800-$1,000.
I would prefer to stay away from vintage units. Also would prefer something easily biased.
I am currently looking at something like a used PrimaLuna Prologue 2, or a Jolida 502crc.
Any input would be appreciated!
Thanks,
Paul
__________________________________________________
Turntable - VPI Scout 1.1/Ortofon 2M Blue
Integrated Amplifier - Rogue Audio Cronus Magnum II
Speakers - GoldenEar Triton 2
7.1 Home Theater
Denon AVR-X3300W; Rotel RMB-1066; Polk CS350ls, LS90's, FXi3's, RC60i; SVS PC Ultra; BenQ W1070; Elite Screens 120"
Man Cave
Turntable - 1) Pro-Ject 2.9 Wood/Grado Gold; 2) Sony PS LX410/Grado Green
Phono Stage - PS Audio GCPH, Parks Audio Budgie; CD - Marantz DV4001
Preamp - Dared SL2000a, Luminous Audio Axiom II; Amplifier - Parasound HCA-1500A
Speakers - SDA 2A (x-overs etc...); Epos Epic 2; Polk Audio Monitor 70 (my first)
  • hochpt21hochpt21 Posts: 5,035
    On the radar...
    Primaluna Prologue 2
    Jolida 502crc
    Cayin A-88t
    7.1 Home Theater
    Man Cave
  • ZLTFULZLTFUL Posts: 4,573
    Thank you @ZLTFUL I have considered a hybrid and Vincent would definitely be at the top of my list, but I think I am looking for a full tubed integrated...and one with the tubes showing :)
    7.1 Home Theater
    Man Cave
  • Msabot1Msabot1 Posts: 2,108
    Not an integrated but I have a Primaluna Prologue II pre that I enjoy quite a bit..Very good build quality..P-P hand wiring is a feature they incorporate into all their products...can't go wrong with that brand..
    Yea, I have really had my eye on Primaluna for awhile now. Their lowest models seem to be on the used market for right around the top of my budget. The Jolida seem to be a little lower in price and I feel like they are a quality brand as well.
    7.1 Home Theater
    Man Cave
  • Check out Decware. You can find their stuff used sometimes for the price you are looking at. Real nice amps that are auto bias and US made.
    Polk S10, S8, S4
    Polk RT8
    Polk Monitor 7s
    Working on getting SDAs
  • Mikey081057Mikey081057 Posts: 5,439
    The Chinese ones are a good value and sound VG when you roll some nice tubes into them.
    HT:Polk LSiM 706 LSiM 705's VR3 LSiM 703's LSiM 702's| Marantz AV7702 | Sunfire TGA-7401 | Oppo BDP-103D | Sony PS4 | Directv Genie HD DVR | Samsung 64" Plasma | SVS PB13 Ultra | MIT EXP 2's (Fronts & Center)
    ManCave: Parasound Halo A23 x2 Amps Parsound Halo A21 Amp & P5 Pre | Marantz AV7004 AV Pre | Usher Dancer Mini-x DMD's| Usher BE-616 Center|SVS Ultra Surrounds | SVS SB4000 Sub |Oppo UDP 203 | MIT Shotgun S3's | Marantz SA8004 SACD | Music Hall MMF 5.3se TT w/ Soundsmith Carmen | Mytek Brooklyn DAC+ | HP Elite Slice PC |Samsung 50" SUHD TV | Sony PS4 Pro
    Patio Polk Atrium 8's |Marantz 2252B |
    Office Bluesound Node2 | Polk SDA SRS 2.3 | Marantz 2385 |
    Bedroom Peactree Nova 125SE | Focal 905's | Bluesound Node | SVS SB2000 Sub
    Garage Yamaha R-N303BL | Polk Monitor 5B's
    Closet Yamaha M80 | 2 Polk MP2K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's |
    Also think about how you are going to connect the subs in the Goldenears
    deucekazoo wrote: »
    I've heard good things about Decware, but I thought thier stuff was all fleawatt types for super efficient speakers. I'll check them out though, thanks.
    7.1 Home Theater
    Man Cave
    The Goldenears have a LFE input, but you don't have to use it. I have mine connected now with just the speakers cables and it sounds great.
    7.1 Home Theater
    Man Cave
  • hochpt21 wrote: »
    deucekazoo wrote: »
    They make some for less efficient speakers. Your speakers at 91 are not too bad.
    You might be interested in this one.
    http://www.decware.com/cgi-bin/yabb22/YaBB.pl?num=1506200373
    Polk S10, S8, S4
    Polk RT8
    Polk Monitor 7s
  • decaldecal Posts: 3,063
    Up your budget a bit and get a used Rogue Audio Cronus Magnum.
  • marvda1marvda1 Posts: 3,145
    i have one of these. great sound and a price to dip your toes into the tube waters.
    http://www.ebay.com/itm/Silk-Audio-MC100SE-KT88-Tube-Amplifier-Factory-upgraded-Yaqin-MC100B-/322795353608
    Amplifiers: MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800, Usher R1.5
    Transport/Dac: Cayin Venus cd-100i, Musical Paradise mp-d2 mkI
    Speakers: Rosso Fiorentino Volterra
    Speaker Cables: Analysis Plus Black Mesh Oval 9, Cerious Technologies Graphene Extreme
    Interconnects: Analysis Plus Copper Oval-In Micro, MG Audio Design Planus Cu2,
    Power Cables by: Cullen Cables, 6sons Audio, Swiss Cables
  • ThortonThorton Posts: 1,113
    Source: Sonos - W4S Mod, DAC: W4S DAC-2
    Pre/Pro: Marantz AV8805
    Amp1: W4S MC-5, AMP2: W4S MMC-7
    Subs: 2 - Rythmik F25's
  • halohalo Posts: 4,311
    I had the pleasure of auditioning a Jolida Fusion 801 paired with ELAC Debut F6 speakers and I was totally blown away by that combination in a less than ideal listening room with minimal room treatment.
    marvda1 wrote: »
    I have one and upgraded all the tubes with Shuguang Treasures and a nice pair of Tesla 12ax7/ecc83 vintage NOS pre tubes. it is very sweet sounding and the KT88's punch pretty nice.
    marvda1 wrote: »
    marvda1 wrote: »
    Funny, I actually found this while searching about a week ago. Just wasn't sure about the reputation of the brand. I'll look more into this one as well.
    7.1 Home Theater
    Man Cave
  • kharp1kharp1 Posts: 2,455
    Have you ever considered going to seperates and starting with a nice tube pre? Find one with dual outs (many have them) and use one set for LFE thereby reducing power needed for the mids/highs. The tube pre will give you a good starting point for the "tube sound" allowing more time to build funds for a future amp. Just a thought thrown out there.
    Main System:
    Joule-Electra LA 100 MKIII
    Pass Labs Aleph 30, McCormack DNA-125, Parasound A21
    Marantz SA-14S1
    Usher CP-6311/Tyler Acoustics Taylo Reference Monitor, LSA-1
    Dual SVS SB2000
    Wireworld Equinox 7 bi-wire, Wireworld Silver Eclipse 7 IC
    Secondary Rig:
    Parasound P5, Audio Electronics by Cary Constellation
    Marsh a200s, Audio Elecrtonics by Cary Hercules
    Pioneer Elite DV-45a, Denon DVD-2910
    Klipsch Epic CF-1, Vandersteen 3CE sig
    Analysus Plus Oval
  • FaustinFaustin Posts: 735
    I have dealt with Silk Audio in the past and I believe other forum members have as well. The owner Ray is a great guy. When I was considering the MC100, he invited me to his place to audition the unit. Purchased it and used it for a year or so and then moved up the ladder to a Rogue Cronus Magnum II. Next step will probably be going to tube separates.
    kharp1 wrote: »
    I have considered that. Part of the issue is that I am needing to sell the Krell, as that was part of the deal of me getting the new speakers. :) The other part is that I am looking to put this gear in a smaller rack and don't think I'd have room for separates.
    One option that I would potentially have is just getting a tubed amp. My GCPH phono pre can be used as a preamp on its own and does a really nice job. I could hook that directly into the amp and be all set. The only problem there is that I would not have the option for any digital music, which although rare, I do use from time to time.
    Hence, what has lead me to an integrated.
    7.1 Home Theater
    Man Cave
  • tonybtonyb Posts: 29,563
    How is an integrated going to solve your digital needs ? You need a dac, most integrateds don't have one.
    Tad 803 bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
  • mikeyb128mikeyb128 Posts: 2,735
    Keep the krell and buy a tube pre. I think sound quality wise, would be better than a 800 integrated. If it were me I would go this route. Or be more patient and save a little longer. There are some really nice Cary integrateds going for under 2000 with upgraded tubes in them, heck I've seen some in the 1500$ range that originally retailed for 5-6000 bucks. I love Cary and feel that one of their tubed integrated amps would outperform brands mentioned above. Not to mention they look as good as they sound. This is somewhat of a biased opinion though.
    2 channel:
    Theater:
    edited October 2017
    tonyb wrote: »
    It is rare that I listen to digital and if then it is never critical. I just hook my computer streaming Spotify through a little HRT Music Streamer dac.
    7.1 Home Theater
    Man Cave
    mikeyb128 wrote: »
    I agree with you. I just have to figure out how to try to fit everything into the space I'm moving it to.
    7.1 Home Theater
    Man Cave
    edited October 2017
    This is how I had my gear at one point. Then we rearranged the living room. Now we are arranging it back and I need to fit it all in there again.
    7.1 Home Theater
    Man Cave
    Aw, man, that's easy...I thought you had some kind of serious space issue.
    Main System:
    Marantz SA-14S1
    Dual SVS SB2000
    Secondary Rig:
    Analysus Plus Oval
  • nspindelnspindel Posts: 5,288
    Funny that you're selling the Krell amp to buy the tubed integrated, Paul. I did the same thing. I got a VPI 299D. Over your budget, but don't let that stop you. Mine replaced the Krell, my tubed pre, phono stage, and headphone amp, not to mention all the cables to hook all that up. Haven't looked back once. Go for it.
  • DSkipDSkip Posts: 14,768
    Cables - that is an area where you begin to see huge value with integrated amplifiers.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
    Bingo.
Howdy, Stranger!
