What color is this?
So I am finally getting around to opening all my lsim speakers I got from adorama. I ordered midnight mahogany. All my speakers are black minus the center channel. Doesn’t look cherry and not black. Do I fight this and have them send me a new one?
https://www.polkaudio.com/products/lsim706c
Receiver Yamaha 3070 *Emotiva xpa5 * Behringer iNuke 6000dsp *Monster Cable HTS 3500 -- line conditioner * Panamax 5300 * Apple 4K * Panasonic UB820 * JVC NX5 * Silver Ticket thin bezel 120”
LSIM - Fronts 707 * Center 706c * Sides 702 * Rear 703 *FP RC85i * RP RC65i * Sub (2) SI HT18
    F1nut Posts: 49,798
    That is Midnight Mahogany. No one ever said they were black.
  • BlueFox
    BlueFox Posts: 15,251
    edited October 2017
    Was the wrong color listed on the box? Anyway, I would ask for an exchange just to match the other speakers. You can exchange the center, or the others. Whichever color you like best.
  • jeremie
    jeremie Posts: 246
    Box says black
    But all my other speaker are black.
    mhardy6647 Posts: 33,042
    This seems exceedingly plausible, although I am being strictly speculative, here.
    The OP:
    ordered Midnight Mahogany
    The speakers:
    are not cherry.
    are not black.
    Too bad black paint is so darned hard to find...
    http://forum.polkaudio.com/discussion/29186/where-to-buy-black-paint
  • BlueFox
    Looking on Polk's site, it appears Midnight Mahogany is another term for Black. LOL.
    F1nut Posts: 49,798
    jeremie wrote: »
    Box says black
    Polk makes two colors in that series, cherry and midnight mahogany.
  • jeremie
    jeremie Posts: 246
    Ok, so apparently under a bright light all of my speakers are that color minus the 702s. My center channels is the only one exposed to direct led lights. I put a light on the 707 and they are the same color. My bad. Move on :)
  • motorhead43026
    motorhead43026 Posts: 3,892
    edited October 2017
    Looks like cherry and black got busy, and you get midnight mahogany.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    The best way to predict the future is to invent it.
    It is imperative that we recognize that an opinion is not a fact.
    Imagine making politics your entire personality.
  • BlueFox
    On Polk's site, Midnight Mahogany is black. No ambiguity. Looks like somebody in Marketing needs to do a better job. Then again, they probably are the ones who wanted Vanilla. :)
    nooshinjohn Posts: 25,098
    Looks like cherry might be getting scarce as well.
  • BlueFox
    Reminds me of the old joke about needing to sacrifice a v i r g i n, but they can't find any. :)
    F1nut Posts: 49,798
    That is pretty much it. You apply a black toner (thinned dye mixed with the clear coat) over the base color, which is likely the cherry color. You end up with a color that appears almost black under low or indirect lighting, but exposes the base color under bright light.
    This technique is currently popular in the furniture industry right now often termed, "Expresso."
  • mrloren
    mrloren Posts: 2,454
    darn hard to stain match too. Been playing with dye a bit, never thought of mixing it with the clear coat, thanks F1nut.
  • Thorton
    Thorton Posts: 1,324
    Yup. It's also a popular technique in the car industry now. And if not done correctly can lead to a blotchy or cloudy appearance. I can't tell if it's the lighting in the picture, the camera or the finish but it looks terrible.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • Thorton
    Yep2 wrote: »
    Thorton wrote: »
    If you cant tell, there are too many variables.
    Wait till you know.
    I'm talking about the picture not how it actually looks in person.
    DAC: Bricasti M1SE
  • hochpt21
    hochpt21 Posts: 5,423
    I really liked the color of the midnight mahoganies when I had them. It does look black when there's not much light but when there is light they have a nice rich brown tone.
    The cherry is a significant difference.
  • BlueFox
    If I bought these speakers based on Polk's photos, which are black, and this mish mash color arrived then I too would be a bit confused or perturbed. They should at least mention the color will vary depending on the light. Is that unreasonable?
  • hochpt21
    BlueFox wrote: »
    I hear you @BlueFox , but the color is described as Midnight Mahogany, not black.
  • BlueFox
    hochpt21 wrote: »
    BlueFox wrote: »
    So? That means nothing. WTF is Midnight Mahogany? LOL
    Viking64 Posts: 6,683
    BlueFox wrote: »
    A prostitute at the stroke of twelve.
  • Thorton
    Polk lists these as Midnight Mahogany. As F1 mentioned these probably are a tri-coat system or a tinted clear. They will look different under a different light sources and also different under the viewing angle you look at them. In many cases, the result is very good. As we all know, it's very difficult taking pictures of finishes that actually show how they look in person.
    DAC: Bricasti M1SE
    txcoastal1 Posts: 13,132
    BlueFox wrote: »
    hochpt21 wrote: »
    BlueFox wrote: »
    The color on my last truck was called pyrite, and didn't look anything like it...it's just a name of a color
  • BlueFox
    And all I am saying is Polk needs to mention the color will vary depending on the lighting.
