Picked up CRS+
monepolk
Yeah I found these on the local CL and they are in good shape. Hoped to be listening to them by now, but i found a little issue.
Coil wires look severed.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Here are some of the other pictures.
No it's one of the inductors.
Is there enough wire to make it into the joint?HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Yeah it will just need a little solder.
President of Club Polk -
Although I also need the interconnect cable. I remember @F1nut mentioned where to purchase the connector. Just can't remember where.
Those look to be in great shape. I have the 4th gen + models and really like how they sound. If you are looking to rebuild the crossovers, go TL modifications if you can.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
gotcha.
I type rather slow.
The pin/blade cable is not available unless you find one used. Best convert it all to Neutrik SpeakOn connections anyway.Political Correctness'.........defined
I'm going to leave them as is for a while.
Why, you're only getting half of each speaker without the cable, not to mention the reason for SDA in the first place.Political Correctness'.........defined
I was hoping I could find the connector and make the cable.
I have one I think and can look for it. PM sent!2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
I told you I type slow
Yeah I'll use the Neutrik SpeakOn then.
My wife went with me to pick them up. So naturally we had to shop for her too.
Some final words,
"If you keep banging your head against the wall,
you're going to have headaches."
Warren -
A coil is the same thing as an inductor.
Dennis Gardner wrote: »Those look to be in great shape. I have the 4th gen + models and really like how they sound. If you are looking to rebuild the crossovers, go TL modifications if you can.
[/quote]
Good I have one of those that he gave me.
The other speaker.
The repair.
Great find. Those look like real veneer. How do you like the soundstage they present?Don't take experimental gene therapies from known eugenicists.
VinylPolitical Correctness'.........defined
