Magnifi sound bar volume
ritchiebob
My Magnifi soundbar has always comes on at high volume. Now its always at high volume and I can't turn it down with either the remote or directly at the bar.
Answers
Hello @ritchiebob,
You need to make sure you do not have the Magnifi plugged into a switched outlet. If you do the power gets reset every time you turn that switch off causing the bar to come on loud.
