Atmos Impacting SC-07 Performance?
So I still have my trusting Pioneer SC-07, however recently noticed a definite sound difference when playing some blurays on the Oppo. After a bit of investigating, it appears that BD with Atmos sound tracks are the culprit. The overall sound is a bit muddy with very little separation in surround channels. I can tell something just isn't right/different. 7.1 and 5.1 BD still sound great.
I know the SC07 is 10 years old now (ancient in the electronics world) and confirmed with Pioneer that there are no firmware updates. My Oppo is set for bitstream and 7 channel set up. The SC07 is set for Pure Direct.
Considering the SC07 does not speak Atmos and never will, is there a different setting I should use for the Oppo and/or SC07 to ensure I'm not losing sound through un-used Atmos channels or just the fact the SC07 can't digest all the information?
Time for an AVR upgrade? Thanks
Parasound HCA-2003A & 2205A
Front: Rti12's
Center: Csi A6
Side surrounds: Polk Rti A1's
Atmos: Mirage Nanosats
APC H15
Power cords by Pepster, Morrow MA4 IC's, AQ Midnight, AQ Chocolate HDMI's[/SIZE]
The rest is TBD.
    pitdogg2 Posts: 24,555
    Since it has been a while since I have viewed any DVD's bear with me.
    Is there separate sound tracks for atmos vs. say 7.1 or 5.1 ? I would think that if you're picking DTS master 7.1 that would be the track it reads and Atmos would not be in the one sent.
  • mikeyb128
    mikeyb128 Posts: 2,885
    What this guy said^^^
    I would change the audio format in the blurays menu. I'm sure that will be easier than a receiver upgrade.
    2 channel:
    Theater:
  • ZLTFUL
    ZLTFUL Posts: 5,640
    Atmos runs via the "TrueHD" soundtrack. I believe the bitstream setting combined with pure-direct is letting the Oppo pass the TrueHD soundtrack instead of letting the Pioneer automatically detect and use a viable soundtrack like DD 5.1 or 7.1.
    Speculating here but try leaving Bitstream on the Oppo and switching the SC to whichever auto setting it has...
  • mufsoman
    mufsoman Posts: 631
    I made several settings changes in the Oppo and set the SC07 to auto surround and reran calibration. All seems to be good. Unfortunately this was not a true controlled experiment where I only changed one variable at a time, so I'm not sure which change was the silver bullet or combination.....
    Front: Rti12's
    Center: Csi A6
    APC H15
    The rest is TBD.
