Speaker placement
jeremie
As many of you know I am redoing my room and starting to work on front placement. I have Polk 707, 706c, FP and 2 SI 18” subs. Should I do the subs in the corners and have the 707 as they are in the pic. Or flush the subs into the walls starting at the Corner of the screen and move the front out wider and back a foot? I have a few feet behind the wall. Sub shown is a Polk PSW1200. Similar size as 1 of the subs.
Receiver Yamaha 3070 *Emotiva xpa5 * Behringer iNuke 6000dsp *Monster Cable HTS 3500 -- line conditioner * Panamax 5300 * Apple 4K * Panasonic UB820 * JVC NX5 * Silver Ticket thin bezel 120”
LSIM - Fronts 707 * Center 706c * Sides 702 * Rear 703 *FP RC85i * RP RC65i * Sub (2) SI HT18
Corner loading the subs is going to give you a much higher output...
Ideal sub placement is either 4 subs at the mid point of each wall or 4 subs corner loaded.
If using only 2 subs, things get more complicated with room modes and nulls. Basing speaker placement solely on aesthetics is almost never the correct way to do things."Some people find it easier to be conceited rather than correct."
