Magnificent mini subwoofer not connect
Hi
Please help!!!! My subwoofer sudnly stop working, I'm following all the instructions to fix it
Press on source button and Bluetooth for 3 second and then on sync button on sub but nothing fix it.
It's worked perfect for 3 month and stopped work.
The sound bar work fine.
Any suggestions? Please help I buy it from Amazon and the local Polk not accept the assurance.
Best Answer
Answers
  • KennethSwaugerKennethSwauger Moderator Posts: 6,302
    Hello,
    Welcome to Polk's forum. It would be best to contact Polk at: 1-800-377-7655 select option 1 for help. They'll be able to get it working for you.
    Regards, Ken
    "That which can be asserted without evidence, can be dismissed without evidence."
    — Christopher Hitchens
  • Unfortunately they not
    Can you explain? Are you living outside the U.S.?
  • Yes
    In that case send an email message to: Ken.Carter@soundunited.com
  • Thanks a lot, I will send him.
  • kobid wrote: »
    Did they fix the problem?
Howdy, Stranger!
