Audioengine B2 Bluetooth Speaker- MINT
markmarc
Next up in the herd thinning is an Audioengine B2 Bluetooth speaker in real light walnut veneer. While it may only be a single cabinet it actually plays stereo. We used it in our dining area for listening to the news during breakfast and when we dined with guests. The wife got hooked on an Amazon Echo so it is time to say so long. While the B2 may just be a single cabinet, it houses a pair of two-way speakers. It is so easy to setup the wife did it on her own in just a few seconds. You can also play them with a wired connection for better than Bluetooth Apt-X sound. The B2 sounds far better than anyone suspects. The B2 has a built-in DAC. New the B2 sells for $225, I'm selling for just $140 including ground shipping CONUS (Alaska, Hawaii, and Canada add $10) in its original boxes. Payment vis PayPal.
Specifications-
Streams audio from any Bluetooth®-enabled device
Easy setup, connects in seconds
No network setup, no passwords, no hassle
Superior sound and extended range
Custom Kevlar woofers and silk tweeters
Hand-built wood cabinet
Dual front port slots for extended bass
Acoustically isolated cabinet design with detachable magnetic grill
Aux audio input
Integrated power supply
Specifications-
High-fidelity Bluetooth® with aptX® transmission and extended range
Supports all Bluetooth-enabled devices
Hand-built wood cabinet with magnetic speaker grills
Auxiliary analog mini-jack input
Built-in auto voltage switching power supply
Type-Powered Bluetooth speaker
Amplifier type-Dual class AB monolithic
Power output-60W peak total (15W RMS, 30W peak per channel), AES
Drivers-2.75” Kevlar woofers, 3/4“ Silk dome tweeters
Inputs-Bluetooth, 3.5mm stereo mini-jack analog
Analog input impedance-10K ohms unbalanced
Frequency response-65Hz-22kHz (±2.0dB)
SNR-95db (typical A-weighted)
THD+N-<0.05% at all power settings
Crosstalk- -50dB
Power filtering-3-stage redundant regulation
Input voltages-100-240V, 50/60Hz auto-switching
Protection-Output current limiting, thermal over-temperature, power on/off transient protection
BLUETOOTH SPECIFICATIONS
Bluetooth receiver type- Bluetooth 4.0 audio
Supported Bluetooth codecs aptX, AAC, SBC
Supported Bluetooth profiles- A2DP, AVRCP
Wireless operation range-up to 100ft (30m) typical
D/A converter- TI PCM5102A
Input bit depth- 24-bit (upsampled)
Input data rate-Determined by Bluetooth
Wireless latency~30 milliseconds (ms)
WEIGHTS AND MEASURES
Product dimensions-4.25”(H) x 12.25”(W) x 5.50”(D)
Shipping weight-10lbs (4.6kg)
Shipping box dims-10.5” (H) x 16” (W) x 7.5” (D)
Specifications-
Aux audio input
Specifications-
Crosstalk- -50dB
Former Staff Member TONEAudio
2 Ch. System
2 Ch. System
