Surround with vintage Polks
I realize this topic has probably been beaten to death, but my topic may be a little unique. My system uses a pair of older Polk SDA monitors up front and I have been attempting to timbre match my surrounds. I was able after a long period of searching to locate a pair of AB700's from Polk. These have the same drivers as the older SDA's. I think I would like to replace my rear surrounds with similar AB models but I am less than optimistic about my prospects. Is there an equivalent model that isn't as difficult to find?
  • [Deleted User]
    Hmmmm. Must be in the wrong forum!
  • FestYboy
    FestYboy Posts: 3,861
    Not seeing how SDAs and ABs are the same drivers... But if you want to match the SDA sound for the rears, look for monitor 4s or 5s or 5JRs. Obviously none of those mount into the wall like the ABs.
  • [Deleted User]
    The ab700 s have the same midranges as my SRS 1.2's but the tweeters are SL1000's. Difficult to find. Ideally I'd like to get another set of these or AB800's. Barring that, something that sounds similar and mounts in the wall would be cool.
  • FestYboy
    Are you talking about the SDA SRTs? Because standard SDAs run 65xx series drivers, ABs do not. IIRC they are a 7000 series driver.
    Maybe a picture of what you currently have would dispel the confusion.
  • FestYboy
    Really Skip? All the pics I've found of the ABs have different baskets than the monitor series...
    Please educate me.
  • TNTsTunes
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
    nooshinjohn Posts: 25,093
    FestYboy wrote: »
    Please educate me.
    I run ab700 and ab800 in my surround locations. Yes, the do use the same doped paper cones as the SDA line. The tweets can be updated to The RDO-194. I believe there may be a TL mod for them as well, but could be wrong on that...
  • FestYboy
    TNTsTunes wrote: »
    Ok that's different then the pics I swap from a Google search. That explains quite a bit.
  • westmassguy
    You can also use a Monitor 5jr or Monitor 4.6.
    I use 3 pairs of 4.6s, and 1 pair 5jrs in as bi-poles.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • FestYboy
    ^ that's what I suggested too (3rd post)
    Great minds think alike? @westmassguy
  • FestYboy
    Well today I got an education on AB series speakers... Turns out the owner of a fastsigns that I contract with was one of the designers of the AB series speakers... And he had a pair installed in the shop that I was able to get a close look at.
  • rooftop59
    rooftop59 Posts: 7,973
    FestYboy wrote: »
    so??? whadja learn???
    Game Room 5.1.4:
    Bedroom 2.1
  • [Deleted User]
    So sorry, folks. I was out of touch a few days. THAT IS A PICTURE OF MY SPEAKERS! Well done. I need a couple more like that.
  • [Deleted User]
    what I'm hoping to do is either find AB700's, 800's or 900's. Barring that, I'm looking for recommendations for similar sounding rear surrounds.
  • FestYboy
    rooftop59 wrote: »
    FestYboy wrote: »
    Well, if I understand correctly, there are 2 generations of AB series speakers... The early ones having the 65xx MWs with SL2k tweets, and the later having the poly-mica cones and tweets from the S series, and there being 2 different bezel plates to accommodate.
    Also I learned that there was an SDA varient that never made production at the behest of Mr Polk himself.
    I find it odd that Polk hasn't kept up with the very thing that put it on the map so to speak (SDA technology).
    Take a look at the RTA line, specifically the 8t or 11t. They also use the same drivers, but they are floor standers. I found that this type of speaker sounds amazing in the surround role.
  • [Deleted User]
    the end goal is to have timbre matched speakers that fit in the wall. I have an old set of SDA-1's which I also purchased in the mid 80's. They would be great as surround speakers but are too friggin huge. Spousal disapproval, bigly. I really need to go in wall with the rear surrounds.
    Maybe for the rear surrounds I get a third set of MC60's to match my four Atmos speakers? Thoughts?
  • FestYboy
    I just came across some ABs (single MW) in my area for what I would consider cheap $10 x 4, if you're still looking for some. I'd be happy to grab them for you and ship them out. I'm waiting for verification that they are still available, and if they are, I'll pull the trigger and wait for your reply.
    I have an extra pair of AB 700..
  • [Deleted User]
    Gentlemen! You are awesome! If you can tell me what the AB models are I may be interested. Otherwise I would love to make a deal for Nooshins AB700's.
  • TNTsTunes
    FestYboy wrote: »
    I'm game for some if he's not.
  • vcwatkins
    vcwatkins Posts: 1,993
    I have a pair of AB700's in the den ceiling. Originally ('95ish) used as surrounds with DefTech BP-2000 fronts. Sounded very good. Currently used as rears with SRS1's as fronts and the BP2000's as surrounds/subs. Sounds great to me, but you can tell I'm of the opinion the timbre matching outside of the front three is not critical.
    b]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
  • FestYboy
    They should be 700s as well, I'll find out today for sure.
  • FestYboy
    Picked them up, they have MW6512 drivers.
  • [Deleted User]
    FestYboy wrote: »
    I'm in. How can I get these from you?
  • FestYboy
    I'm in Lititz PA, so I can ship, or if you're close...
  • [Deleted User]
    I am in Minnesota. Shipping would be best
  • [Deleted User]
    Any good way I can pay you and the shipping?
  • FestYboy
    Yessir, I'll pm you my PayPal. How many unit do you want? I'll likely ship USPS in the prepay boxes after I clean them up a bit.
  • FestYboy
    Gonna pull one of the MWs apart: possible shifted magnet. Will test first and update. Should have results Monday evening at the earliest but no later than Friday. Working nights for this week.
