looking for surround speakers to compliment my RT55i's
_mo_
Hey All,
I recently picked up a set of RT55i's with the matching center channel speaker off a neighbor, I'm pretty excited about them! Got them cheap, they just needed a little TLC as the black trim was peeling in a couple places.
I'm getting ready to redo my basement and was going to use them for the surround system I'm going to build down there. I'm wondering what folks recommend as good surround speakers and subwoofer to compliment theses. Given my basement setup I'll probably be hanging the surrounds from the ceiling. Looking to do a 5.1 system, but am open to hearing ideas for a 7.1 system as well.
Family Room 7.2.4: S35, S60, S10, MM2104 endtables, TL1
Basement 5.1.2: CS400i, RT55i, RT25, PSW450, MC60
Living Room Stereo: SDA 2a
RT/fx
RT25's or RT35's if you can find @ken brydson suggestion.
Awesome! there was actually a pair of RT/fx on Ebay just now, so perfect timing. got them for under $50 including shipping. Thanks!
Any thoughts on a sub?Family Room 7.2.4: S35, S60, S10, MM2104 endtables, TL1
Living Room Stereo: SDA 2a -
Sub boils down to room size and budget.
Time to do some research. The sub in my Living Room setup just died, so looks like I'll be looking for 2 new ones.
Thanks again for the help. I'm looking forward to my new basement project!Family Room 7.2.4: S35, S60, S10, MM2104 endtables, TL1
My setup is similar to yours. I went with a SVS PB-1000 subHT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5 -
I decided to go 7.1. Got the rt/fx for the side surrounds and the rt25 for the rear. still looking for a good sub and receiver, but I have until Thanksgiving to figure it out. Thanks to everyone for the suggestions!Family Room 7.2.4: S35, S60, S10, MM2104 endtables, TL1
You need a psw1200 sub
