SDA-2B wiring diagram
Speedbump71
I have a set of SDA-2B's that I pulled apart for refurb a couple years ago, then boxed and put in storage. I am done refurbishing the cabinets, and even though I had the wiring pretty well organized, the interior wiring of the SDA-2B just seems wrong. I only have one conductor going the the crossover cable jack, and I'm unsure which colors are +/- on the two mid drivers. one mid has black/white wiring (I think black is +, white is -). Same for the tweeter. The other 6 1/2 inch driver has a blue wire and a green wire. Which one of those is + and which is -?
Thanks for your replies.
If your 2B's are blade/blade you will have only one wire going to the SDA socket. Black or blue is positive, white or green is negative.Political Correctness'.........defined
President of Club Polk -
Thank You!
