Monitor 70 Series II - Help Setting Up Properly
I am a noob here, but have a few quick questions about how to proper wire up my Monitor 70's for all around use. We will be using them for everything audio and video. My set up is as follows: 3.1 front facing (We don't have the space or ability to run 5.1 or 7.2)
Reciever - Yamaha RV-V579
Line Cleanser/Surge: Monster Power Center HTS2500
Mains: Monitor 70 Series II (Bi-Wired)
Center: Polk CSi3 Center
Subwoofer: Polk PSW 404B (Sits Next to Right Main
Speaker Cables: CL1 14-4 (Bi-Wire Mains/Single Center)
With the way I have my 70's wired, should I remove the jack plate or just leave it? I have been lurking for a week now trying to read up on as much information as I can find, but no one really answers my question above. Most of the answers are more opinions or personal preference. I have been playing around with different wiring techniques, and so far bi-wiring the mains has produced the best clarity, power management, highest volume without distortion, and overall sound quality. My Yamaha just doesn't have enough power (80 watts per channel) to run the Monitor 70's with 1 cable Main A to Top Jack. I also ran Main A to Bi-Wire (14awg 2 plugs to 4 plugs). I ended up building my cables to run 14awg - 4 plugs. Is there anything else can I do to help get the most out of the 70's with what I have to work with. Before anyone suggests buying 1 or 2 amps, this is not an option for me as this time. My electronics budget is gone for this year and maybe next.
Thanks for reading this entire mess, and I hope it makes sense.
Answers
  • afterburntafterburnt Posts: 4,053
    With 4 plugs the plates are redundant
    Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
    Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
    Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
    Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
    Hello Kitty boombox
    Spare sortta: ifi iDsd nano*Marantz 1504* RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*Samsung BD-H5900 3D Blu-Ray*Usher N-6361
    Self Control is over rated.
    Mr. Sharpe wrote: »
    Meh these were extra $70 as an open box item so it didn’t much to me either way:)
  • tonybtonyb Posts: 28,716
    edited August 2017
    If your bi-wiring, then remove those jumper plates on the back of the speakers. You need to re-install those plates if your going to run just a single speaker wire.
    Getting the most out of them can come from different areas but at this point, your receiver's settings. Make sure you setup all your inputs individually. Read your manual as to all the adjustments available to you. If you have auto calibration on that receiver, use it as a guideline, and then tweek the settings to your satisfaction after. Since you don't have surrounds, make sure you tell the receiver that so that information gets re-routed to the front 3 instead of being lost.
    Personally, I like larger speakers set to large, even with a subwoofer, but most will tell you to set them to small, with the crossover set at roughly 70-80. Try either way to see what satisfies your ears.
    ....forgot my manners, welcome to the forum. ;)
    Sony BRP
    Tad bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
Howdy, Stranger!
