Equipment protection, dust mites, cat hair, human hair.........
heiney9heiney9 Posts: 23,694
I have a dust problem in my house in general. It also doesn't help that one end of my rig is very close to a heating/AC vent, so I get a lot of dust accumulation. I dust regularly, but it still is a nuisance.
I am thinking about having some custom dust covers made for my 2 channel rig. I found this company which gives many choices of fabrics and materials, etc.
https://www.digitaldeckcovers.com/
Anyone heard of them? Used them? Or have an alternative? I'm not looking to spend a bunch of money. Just something that fits well and looks nice to combat the dust issue. The dust is getting inside the vents of the gear too, so that's the main reason I'm also looking.
Discuss
P.s. Oh yeah the cat hair and the GF's long hair are an issue too, just to a lesser extent than the dust. Me, I don't have much hair left so I know it's not mine...lol
"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass
Pass Aleph 30 | EE Avant Pre | EE Mini Max Plus DAC | MIT Shotgun S3 | MIT Z P/C's | updated SDA 1C| SQ Box Touch/Welbourne Labs P/S- Tubes add soul!
  • EndersShadowEndersShadow Posts: 15,596
    edited August 2017
    @SCompRacer used them and posted about it IIRC
    **edit** here is it (photobucket nuked though)
  • heiney9heiney9 Posts: 23,694
    I knew he had some made, but I forgot who it was that made them for him. Thanks!
    This link is to this thread...lol
  • pitdogg2pitdogg2 Posts: 9,813
    tonyb wrote: »
    Protection ??
    300 a month and I'll beat that dust back into the vents. ;)
    I'll take that bet B)
    I had the same dust problem. I just use my air compressor and blow it out spring and fall.
    I don't doubt that you would Tony...lol.
    I have been doing the compressed air thing, but it's a PITA and it never gets it fully out of the gear. I think the dust covers will work well. I did a search after I posted, and it seems they have been mentioned before.
    My rig gets little use in the Summer as I am much more busy and don't have the time. But also the rig runs hot, and in the Summer it really heats up the room, so I tend to avoid the rig a bit more. But mostly it's a time thing in the Summer months.
    edited August 2017
    heiney9 wrote: »
    Lets try this again (here)
  • msgmsg Posts: 4,037
    I have a similar problem, one room in particular. Planning to inspect and replace the supply duct there to see if it helps.
    I hadn't thought of doing this with audio gear yet, especially some of the pieces that still generate significant heat in standby, but I use little microfiber cloths to drape over stuff like a computer printer and a scanner, which really helps keeping rollers clean to avoid feed problems.
    Come to think of it, I'm also using one of the soft, clothy packing 'bags' that came with the 703s, folded and draped over the Onix tube integrated to keep the dust off it. This is my only piece of tubed gear at the moment, and that's enough for it to be a nuisance without dust protection.
    Microfiber towels probably wouldn't work if you have a cat that likes to lounge on your stuff.
    DigitalDeckCovers looks like a great resource for better protection.
    Along similar lines, I also use this for maintenance dusting, which really helps and has been nearly painless, doesn't really feel like work, and actually kinda fun to use because it works so well. Still kinda like being forced to eat my vegetables, so I don't always do it as often as I should.
    https://www.amazon.com/gp/product/B006EPLEN2
  • SCompRacerSCompRacer Posts: 6,737
    Extortion bucket sucks!
    Make yourself necessary to someone. Ralph Waldo Emerson
    Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ & Pro 11+ * Signature Series Sonore Music Server w/Deux PS* Twisted Pear Buffalo III Dual Mono ESS Sabre32 DAC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
  • kharp1kharp1 Posts: 2,318
    I like it!
    Main System:
    Joule-Electra LA 100 MKIII
    Pass Labs Aleph 30, McCormack DNA-125, Parasound A21
    Marantz SA-14S1
    Usher CP-6311/Tyler Acoustics Taylo Reference Monitor, LSA-1
    Dual SVS SB2000
    Wireworld Equinox 7 bi-wire, Wireworld Silver Eclipse 7 IC
    Secondary Rig:
    Parasound P5, Audio Electronics by Cary Constellation
    Marsh a200s, Audio Elecrtonics by Cary Hercules
    Pioneer Elite DV-45a, Denon DVD-2910
    Klipsch Epic CF-1, Vandersteen 3CE sig
    Analysus Plus Oval
  • quickr1quickr1 Posts: 384
    When is the last time you had your duct work cleaned out?
  • ZLTFULZLTFUL Posts: 4,417
    2 Channel: Silverline Audio Sonatina MKI, Monitor 5 Series II, DIY Seas based bookies
    LR 2 Channel: LSi7, DSW-MP2000
    HT: JTR Triple 8 LCRs, DIYSG Volt 8LX Surrounds, DIYSG Volt 6LX Atmos, 6 SI HT-18D2 Subs
    Guest BR 2 Channel: Swans D1080MKII
    Deck: Pyle BT Speaker pair with upgraded woofers
    May not matter. We had ours done 6 months ago and we still get bad dust
  • UpstatemaxUpstatemax Posts: 2,209
    tonyb wrote: »
    Protection ??
    He is just going to sit in your chair giving dirty looks to your AC vents, in his undies.
    Rocking a pair of these:
    Living room:
    Samsung PN50B860 50" Plasma : XBOX One : Roku 3 : Oppo BDP-103 : Pioneer Elite SC-87 : APC H15 : Focal 806V mains : Focal 806V Surrounds : SVS SB2000 : SVS SB12-NSD
    2Ch:
    Sonus Faber Venere S : Parasound HCA 1500A : Oppo UDP-205 : Furman Elite 15 DM i : Sony XBR 55X810C Monitor :
  • lightman1lightman1 Posts: 9,441
    Brock......face it......you're just nasty.
    Some house's no matter how clean the ducts are they are just dusty...
    But it can't hurt if it has not ever been done
  • mrlorenmrloren Posts: 1,335
    I get a lot of dust too. It's not from the ducts I am in SoCal and don't use the forced air most of the time.
    Whenever I vacuum I go over the top of my gear to get any dust up. once or twice a year I will pull it out take the top off and compressed air them out. most of the time there is no to very little dust inside. I am kind of a clean freak, I vacuum at least once a week.
    Family Room:
    Samsung UN60H,
    Marantz SR5010, Emotiva BasX-A300
    Oppo BDP-93,Sony UBP-X800BM, Sony DVP-NS3100ES, WD Live HUB.
    Main: Polk Signature S60
    Center: Polk CSi-A6
    Front High TC80i
    Rear: Polk MC80
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Marantz SR5010, BDP-S270
    Main: Polk Signature S20
    Center: Polk Signature S30
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Polk RTi4 about 15' up the wall
    Old sony 12" Sub
    Mini tower PC with 400GB of music
  • gmcmangmcman Posts: 1,054
    Check your dryer vent for any leaks. At one time I was getting a little more dust than usual, the joint where the flexible pipe from the dryer connects to the solid round pipe was barely pulled away, but was enough. Also check the entire length for any leaks.
    Not sure what air filters you use, but stay away from those 30-day, woven, see-thru filters.
    edited August 2017
    My house is older and even cleaning the ducts doesn't help all that much. I even use a good furnace filter.
    Since the GF moved in with her cat (whom I love) it just seems to be worse, or atleast the cat hair is.
    heiney9 wrote: »
    I do not doubt that Brock. Unlike dog hair cat hair floats up and around the house pretty easily.
    He's a light colored cat so the "hair" blends in the carpet and most of my light colored furniture.
  • Another source for dust covers, seems less expensive, no history myself with this...
    https://buypcsupplies.com/
  • pumpkinmanpumpkinman Posts: 5,909
    Because I am The Pumpkinking
  • VR3VR3 Posts: 21,940
    My house is chronically under construction
    I have a blue air 200 series in both bedrooms and a blueair 500 series in the common area.
    Change filters every six months, it's awesome.i also use MERV 11 filters monthly.
    Vr3Mods.com ///// Version3Audio.com
    "No, that's silly talk. Dude, you can't possibly be this audio dumb so quit the act." - Doro
  • smglbrthsmglbrth Posts: 1,059
    I had a couple made around 4-5 years ago from Digital Deck Covers. Black, no frills, they work well and have lasted. One thing if you do measure, take into account the wires hooked up into the back of your equipment. This alone will make the measurement deeper. It was either that or cut them once I got 'em. Didn't feel like cutting them up in case I changed equipment (which did happen). RCA's take up more room than you'd think.
    Sorry I'm late to the party..., my .02...
  • LeftCoastLeftCoast Posts: 386
    I had the exact same situation. My girlfriend moved in.
    I asked my girlfriend to shave her cat. I've been super happy ever since.
  • ken brydsonken brydson Posts: 6,936
    LeftCoast wrote: »
    HT/Main- Panny 50" G10 Plasma, Pioneer SC-1222k AVR, Panny DMP-BD60 BDP, Polk LS90 mains, CS350LS center, LS/fx side surrounds, LS50 surround backs, SVS 25-31PC+ sub, Harmony One
    Office Rig- Marantz 2252B, Denon 2910, Kenwood KD2070 TT, Polk RTA 12B's/ RTA8t
  • Tony MTony M Posts: 5,355
    Cat hair..
    We have a cat with med. hair.
    We use a "shedding brush" quite often.
    On one side is a lot of med. long hard pins set at a slight angle. They don't give at all. These pins will get most of the cats loose hair off of it.
    Then the other side is a thick firm brush. It will get the remaining hairs the pins didn't get. Our cat stays petty shedding free. It's not 100% effective but darn close. Once a week maybe. Our cat seems to know what we're doing and kind of lets us do the routine and then lets us know when she's had enough..LOL.
  • Yep2Yep2 Posts: 1,087
    heiney9 wrote: »
    Discuss
    Air compressor with a water filter is a good investment if your into audio.
    Spray out all components with a simple top cover removal.
    Works great for other tasks around the house also, but almost indispensable for cleaning out a component/chassis.
  • zeppage2zeppage2 Posts: 156
    https://buypcsupplies.com/dust-cover
    Bought from them to cover tubes on Rogue Audio equipment.
    I like them and the fit is great if you measure correctly.
Howdy, Stranger!
