Does this waveform look clipped to you?
msg
I was splitting up a .flac into tracks and was a bit surprised when I saw this after importing.
Does this look clipped to you?
I don't really know a whole lot about Audacity, and this could also be a problem with my rip method, so I need to check a few things before drawing any conclusions about this album. It's very loudness-dynamic, and has some really quiet passages on it, but wondering whether this could be one of "those recordings" I've been reading about.
I disabled signatures. -
Looks more like the loudness wars than clipping. Can you hear the clipping? Usually it's pretty noticeable unless it's just on the edge.
Hard to say as my Audacity days were a long time ago.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
Dynamics and loudness aren't the same. Think of dynamics being the difference between the loudest and softest passages of a song or album. Something that is dynamic has a large swings between loud and soft passages.
Loudness is just loud, all parts of the musical composition are at the same basic level of output. No variation between different instruments, vocals, drums, etc. You just know it when you hear it kind of thing.
H9Post edited by heiney9 on"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
I agree with Brock. Loudness wars makes it so when you try and turn up the CD/File it just gets unbearable to listen to. No definition between anything just loud and distorted after a certain point. A brick walled CD you cannot listen to cranked up they just become nasty distortion.
Ah, yes, the Loudness Wars - I think that's what I was thinking. Isn't that where an engineer will "normalize" the track at the end, to boost everything relative to the average max peak?
I'll zoom in and take a closer look here. I can't really tell whether it's clipped or not by the audio, though there's been some discussion of the quality of the vinyl version. I should see squared off tops at the wave peaks if it's clipped when I zoom in, right?
That second screen capture above looks oddly, too-neatly sculptured to me too, so I wasn't sure whether that was a result of clipping somehow, as well.
What you describe dynamics to be is what I intended by with the loudness-dynamic descriptor. Didn't quite know how else to describe the character of music, eg varying from soft/quiet varying to very "loud", so used Loudness to describe the perceived output level. Maybe Levels more properly describes what I meant.Post edited by msg onI disabled signatures. -
yes IMHO you are seeing clipped signals in the waveform.
My experience says the audio was recorded with compression to keep from clipping (why you see a few areas above the shelf, not quite enough to trip the gate). This also allows the average volume of the track to be boosted to keep from having a quiet CD.
Interesting. How would that be, 'recorded with compression'?
What's the shelf? I gather gate = threshold?
AP - Thanks for that link to the section of the manual. I need to read up for sure. I actually stumbled across something similar while trying to figure out how to determine whether it was clipped. I decided to force clipping by amplifying the audio, just to see what clipping was supposed to look like. It's just like what you posted - clipped audio section shows in red, and when you zoom in, it is indeed squared up - as if dragging a line across a ceiling.
I've got a lot to learn about audio recording, and I'm not sure I even want to know or be aware of it. I still have to wonder whether and how a recording can be similarly damaged by the time it's in mastering.
I think one of the things I'd like to try for fun is to record a track into Audacity from an LP, and then compare the waveform to a digital rip to flac.I disabled signatures. -
Durring the mastering process, the mix can be put through a compressor to help push the average dB level up so that the main L&R channels don't clip durring transients or go into distortion at the digital level.
Really it comes down to poor prep and poor initial track capture by the engineer, and that's how they fix it post production. Any compression should have been done during the initial recording, not in post. -
That sounds gross.
I just had a visual of a meat grinder.
But I'm in vamp apprenticeship under F1, and so am just up from a nap, not thinking clearly yet, and my hair's sticking up all over the place. (Clearly I'm still a novice.)I disabled signatures. -
It is gross. With over a century of recording technology at our disposal, and all the knowledge that comes with it, there's no reason to have a poorly recorded and mastered piece of music anymore, ever.
Looks compressed to me. There should be an option in the audacity menu that allows to show clipping.
There is, and it doesn't show clipping. I need to show you guys some more screenshits. I amped the file to induce clipping to see what that would look like. It shows up in red. I don't know enough about waveform analysis to know what compression looks like. What are the defining characteristics of compression? And is it the same as the Loudness Wars?I disabled signatures.
Please no screenshots ....that's just grossPost edited by [Deleted User] on2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
That's a funny typo ya' got's there, msg. Too much fiber today?
Lolol waaay too much fiber!
You know it's bad when your shorts look like shrapnel tore through metal.
Sorry Ron. Safety first - shield your eyes.I disabled signatures. -
As Russman would describe ....green apple splatters2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
