Ifi micro RCA output voltage?
afterburntafterburnt Posts: 4,405
edited August 2017 in Going Digital
I am trying to use this as a DAC the FAQ says: Voltage output - RCAs
Eco: 2.2v (volume at 100%)
Normal or Turbo: 5.5v (volume at 80%) or 6.5v (volume at 100%)
It is either 0dB (Eco) or 9dB (Normal/Turbo)
Direct: 2v
Pre-Amp: Depends upon the “mode” please see vol pot instructions.
I was thinking the RCA output would be fixed and not vary with the volume knob setting. Anyway do in need to be concerned with the voltage going to my preamp? Anyway the preamp/direct switch would defeat the knob according to the FAQ, no?
Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
Hello Kitty boombox
Spare sortta: Usher N-6361* ifi iDsd nano*Marantz 1504* RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*Samsung BD-H5900 3D Blu-Ray*Usher N-6361
Self Control is over rated.
Mr. Sharpe wrote: »
Meh these were extra $70 as an open box item so it didn’t much to me either way:)
  • afterburntafterburnt Posts: 4,405
    Before yall start yelling at me, I asked ifi and they are stoopider than me!
    Hello Kitty boombox
    Mr. Sharpe wrote: »
    Here's the manual. Item 12 is what has me confused "bypass, FULL volume"
    Hello Kitty boombox
    Mr. Sharpe wrote: »
  • DSkipDSkip Posts: 14,569
    Yes it should. It then becomes a line level and not a pre-out.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
    Therefore the voltage will not change until I rotate the volume control to the maximum position?
    Hello Kitty boombox
    Mr. Sharpe wrote: »
    The voltage should be fixed in bypass mode.
    audiothesis.com/
    Cabling: Wireworld
    Excellent!
    Hello Kitty boombox
    Mr. Sharpe wrote: »
Howdy, Stranger!
