Flat-panel TV between speakers, how to treat or diffuse?
gmcman
I have a 65" plasma between the 2.3 TL's, speakers are about 8" from back wall, but the TV is about even with the rear of the speakers. Being a plasma, the screen is glass, so any recommendations on treating the panel when listening to 2CH would be greatly appreciated.
I can probably move the speakers out a tiny bit, then slide the TV back some, but mounting on the wall could prove to be difficult for side viewing, If I can leave it on it's own stand that would be great.
How does it sound as you have it know?Some final words,
"If you keep banging your head against the wall,
you're going to have headaches."
Warren -
Please remove the "k".. sorry..Some final words,
Warren -
Can't sound that bad imho.
If you must, just use a blanket... -
It sounds good, I just don't know if it's bad juju to have a protrusion from the wall like this when dealing with SDA's.
The TV nearly fills the entire gap between the speakers, with 4-5" gap between edge of tv and the speaker cabinets.
I could always remove the tv and test, but just curious If anyone has noticed any detrimental effects with a setup like this. -
My first thought is not a problem but I have been surprised many times with this hobby.
I would test with and without to make sure.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
I have a standard LCD that is about 1" behind the back of my 1c's, and 5-6" from the sides. The bottom 1/4 of the TV is below the top of the speakers. I don't notice any detriment. Worst case hang a curtain over the TV and open and close it like a movie theater.
