T50 continous power handling??
WannaKatana
in Speakers
I don't seem to be able to find the continuous power handling, only max which really is a useless number in general.
Welcome to the forum!
A lot of times, the continuous is about half of the max. Maximum assumes only brief peaks of music or sound.
Either way, neither number is truly a set in stone number.
Just try to have enough clean watts that it will easily play at levels you need and a bit more.
Clipping hurts speakers more than just "Too many" watts.
Found a review of them:
https://www.soundandvision.com/content/polk-audio-t50-speaker-system-review
Just remember, with one 6.5" woofer, there is only so much they can take.
What size room and what kinda listening levels do you normally use? -
Thanks. I guess I'm just curious why the lack of what used to be the import spec for speakers. Even the article you posted I didn't see continuous power handling. Understood about the clean power.
Your ears will let you know. When it starts sounding a little shrill and the stage collapses you've gone too far a while ago.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk
