TL 250 rubber base
Hey guys, searched the forum and I couldn't find my answer. Unfortunately, I cannot wall mount my speakers and have to use stands. The stand mount options, although vast, didn't quite fit the TLs. I had to remove the rubber base to the satellites and it appears to be just a bit of a weight. This isn't some super important sonic masterpiece part of the TL, right?
  • codycatalistcodycatalist Posts: 1,536
    edited August 2017
    I would have to assume that they would serve a purpose other than weight. It looks like it keeps the plastic base off the ground which would rattle/move/resonate. My vote goes to keeping that rubber base on.
    Are they just regular stands or are the sats mounted to the stand so there is nothing touching the bottom as that would dictate what I would do.
    Living room
    Mains: Paradigm 90P
    Lows: Velodyne CHT12, Pioneer SW-8Mk2
    Power: Marantz SR7000
    Tv: Samsung UHD 55' Curved 4k
    2 Channel Den
    Mains: SDA2B Upgraded XOs and Binding Posts
    Pre: Denon PRA-1200
    Power: Adcom GFA-545
    TT: Pioneer PL510
    Tv: Samsung UHD 55' 4K
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Little dot 1+/GE JAN 5654w
    Closet of Dreams:
    Harman Kardon AVR130
    Yamaha HTR5590
    Polk RTA11TL
    Polk TSI200s
    New Large Advents 25th Anniversary Edition
    Bravo V2/RCA Clear top Conn branded 12AU7
    Yamaha AV-34
  • The sats are mounted, which is why I took them off. My other option is to not mount them and use some tape to hold them on. By going that way, the stands have a base plate that is juuust a bit too small and one that is HUGE. Removing the rubber base and mounting them with one of the supplied mounting plate has the cleanest look (and nothing should rattle). I should be all set up tonight, so I'll give it a real strong test.
Howdy, Stranger!
