the cloth behind the grill on the RC-65i in-wall speakers
baneling
Hi all, I just finished installing the RC-65i in-wall speakers. there is a fabric behind the grill. Can I remove this fabric? what's it for? I notice that when I'm watching a movie without the grills on, these speakers are as loud as the main fronts. I figure when I put back the grills, the sound will be a bit lower cause of that fabric. that's why I'm hoping I can take it off.
Also, behind the tweeter there are some small components that yellow, white and a blue one and also copper coil. those are touching the plastic vapor barrier inside the wall. does that area get warm? I know I should have asked before I installed them. here is a picture of it:
https://www.google.ca/search?q=polk+audio+in-wall+speakers+fabric+behind+the+grill&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjSkISG8rHVAhUi3YMKHRS-CswQ_AUICigB&biw=2560&bih=1299#imgrc=2lrx4MXHpRlKZM:&spf=1501448755413
thanks
thanks
www.jvpix.com
Yes you can remove the barrier, they do come in handy if you paint the grills
If it's a membrane barrier like Tyvek it won't get hot enough to burn2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
what's the purpose of the cloth behind the grill?
www.jvpix.com -
Paint
To keep it off the drivers in new home construction2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
wouldn't someone just put the grill ontop of some newspaper or something and spray paint it?
www.jvpix.com -
I am a dealer/installer
If that layer wasn't there, we would have over spray on the drivers
Contractors don't pay attention during new construction2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
