Good inexpensive 3.5mm to 3.5mm cable and .25" adapter together or seperate
afterburntafterburnt Posts: 4,411
Looking for a durable upgrade for Audio-Technica ATH-MSR7 cheap but good.
Merci
Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
Hello Kitty boombox
Spare sortta: Usher N-6361* ifi iDsd nano*Marantz 1504* RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*Samsung BD-H5900 3D Blu-Ray*Usher N-6361
Self Control is over rated.
Mr. Sharpe wrote: »
Meh these were extra $70 as an open box item so it didn’t much to me either way:)
  • voltzvoltz Posts: 4,946
    edited July 2017
    oh man I had a adapter for you the does they 1/4 to mini jack made by Grado that is excellent. I should have sent you. the other way around .25 to 1/4 or 3.5
  • afterburntafterburnt Posts: 4,411
    voltz wrote: »
    I could use both small to large and large to small because of the extension. The adapter that I am using with your Micro is pretty temperamental but it all depends on which cans and cables. Some of these OEM cables that I have are like thin as thread. I will look up the Grado and see if I can get one.
    Hello Kitty boombox
    Mr. Sharpe wrote: »
    it came with some Grado cans I sent Scott/msg... I use it from my PC to my SENN 598's
    Hello Kitty boombox
    Mr. Sharpe wrote: »
    Bingo, my brother!
Howdy, Stranger!
