DSW Pro 660
Hi and sorry if this is posted in the wrong place, a couple weeks ago my DSW 660 subwoofer stopped working , after contacting the amazing people at polk audio CS they sent me a new amp. and when I pulled my old amp out I immediately saw what the problem was.check the pictures below and any advice of what might happened and what to do to prevent this in the future would be much appreciated.
    F1nut Posts: 49,801
    It done blew up......
    Hard to tell, but stuff happens and it's highly likely it had nothing to do with you.
    txcoastal1 Posts: 13,132
    agree^^^^
    That looks like a malfunction or possibly a lightning strike
  • max290
    max290 Posts: 2
    Thank you guys , I wasn't really sure about what has happened and if it is something that can be avoided.
  • polrbehr
    polrbehr Posts: 2,826
    edited July 2017
    I had an outdoor GFCI receptacle that looks just like that. Practically burned up inside the box, no reason for it either; it was properly mounted in a weatherproof enclosure and it didn't even have anything plugged into it when it happened. If it wasn't for the strong odor it gave off, I wouldn't have even known anything was wrong.
    Just chalked it up to stuff happens I guess, but lucky my house didn't catch fire.
