Sda 1C high pass inductors recommend
Looking to grab some,not all inductors with my booty of Clarity ESA's at Madisound. Got (4) 6.8 ohm Moxes for 7.5 in my cart, am I tragically failing or squeak by?
listen to Alex Jones.
  • westmassguywestmassguy Posts: 5,969
    What's wrong with the ones that are in there?
    Home Theater/2 Channel:
    Cables: Speaker: Furez 10/2 with GLS Locking Banana Plugs
    Interconnect: Furez 10/2 with SpeakONs
    ICs: Custom Furez by Douglas Connections
    Den:
    Bose 901 Series II Continentals Restored, Re-Built Equalizer with Elna Silmic IIs, Sonicaps, and Silver Mica Caps
    Carver CT-3 Pre, Carver C-500
    dhsspeakerservice.com/
    Now Carrying Gimpod's Custom SDA Circuit Boards
    "And keep her under 70, would you, huh? Betty likes a slow ride"
  • SmalliesSmallies Posts: 279
    Just found these pics but Jantzen not at Madisound, carry on.
    https://us.v-cdn.net/5021930/uploads/attachments/4/7/1/5/3/80622.jpg
  • nbrowsernbrowser Posts: 7,742
    Good question, I can't see an inductor going south like a cap or resistor does....mainly cause it's just wound wire...I could be wrong mind you.
    Living room: Samsung UN55KU7000 4K UHD HDR 55 inch TV, Marantz CD6004, Pro-Ject Debut Carbon, Parasound zPhono, Mac Mini, Oppo BDP-93, XBox One S 2Tb, Kenwood DPX792BH car deck for radio purposes, Marantz SR5010 AVR, Parasound HCA-1200II, Front SDA 2 modded with Larrys Rings and RD0-194-1 tweeters, Rear Onkyo SKF-4800 Towers, Center CSiA6, BOOM Tannoy TS2.12 Sub, Audioquest Evergreen interconnects just about everywhere except from AVR to amp, MIT Terminator 4, MIT AVT3 speaker cables with extra terminals covered up Monitor 5 Jr+ in the wings for a center channel.
  • F1nutF1nut Posts: 39,303
    Smallies wrote: »
    That ohm difference is quite audible.
    oops, had to pull the trigger. $130 for all ESA/Mox and 4 cheap posts! Wandered over to Vampire and BP Hex are 70 bucks??!!???
    If you ever sell them be sure to tell the buyer you put the wrong value resistors in them.
    Stick it Jossy.
    Good Lord...............
    Den:
  • pitdogg2pitdogg2 Posts: 9,436
    I have to wonder what the rush was to get something bought that was not right?
  • vmaxervmaxer Posts: 4,193
    Really, curious myself.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • VR3VR3 Posts: 21,879
    Should have gotten 2 * 15 ohm mox, parallel. = 7.5 ☺
    Vr3Mods.com ///// Version3Audio.com
    "No, that's silly talk. Dude, you can't possibly be this audio dumb so quit the act." - Doro
    Not a big puzzle guys, I was hyped on snatching up all ClarityESA at big discounts. If I get more tweeter that's fine (double elazovj5ijhov.jpg
    specially considering 194's) but sl-2,000 are fine and check out my 33.5' room. ps those mox leads suck so thin!
  • Viking64Viking64 Posts: 2,193
    Where does that ladder lead to? Are there any old Playboys hidden up there? Or maybe secret pirate treasure?
    Hm, nope nothing good but a ton of kitchen utensils and bowls to make Lipton vegetable sour cream dip.
Howdy, Stranger!
