Monitor 10 gasket
Getting ready to mod a pair of Monitor 10s, and noticed that one of these is not like the others. There is no trace of the fourth gasket.
I guess weather-stripping or some other foam tape is the best replacement. Does Polk offer an OEM gasket replacement?
  • F1nutF1nut Posts: 39,303
    Not unless you buy a new driver. In your case some Armacell or the like will get the job done.
  • jdjohnjdjohn Posts: 278
    Thanks, Jesse. Will search out Armacell or equivalent. Interesting how the problem-child driver has the extra stickers on it :/
    This will be my second pair of M10 upgrades. Looking forward to getting them back into circulation for another couple of decades.
    I can't read the stickers, what do they say?
    The other three only have the one big circular sticker.
    Is 12771 the serial number on one of your speakers?
    Don't think so. Sticker numbers on the back-side of the xover plates are 96XXX and 99XXX.
    Hmmm.......you got a strange one.
  • skrolskrol Posts: 2,615
    Which Armacell is recommended. All I have found is rather thick. Is there a thin Armacell?
    Stan
    Main 2ch:
    Polk LSi15 (DB840 upgrade), Parasound: P/LD-1100, HCA-1000A; Denon: DVD-2910, DRM-800A; Monster HTS3600-MKII, Grado SR-225i
    HT:
    Denon AVR-888, Polk: RTA11TL (RDO198-1, XO and Damping Upgrades), S4, CS250, PSW10, Marantz UD5005, Panasonic TC-P42S60
    Other stuff:
    Denon: DRA-835R, DCD-660, DRM-700A, DRR-780; Polk: S8, Monitor 5A, TSi100; Pioneer: CT-6R, PL-530; Onkyo CP-1046F; Ortofon OM5E, Marantz: PM5004, CD5004, Polk: RM7, Parasound C/PT-600, HCA-800ii
    Look for Armacell tape. I'm seeing some on Amazon that is 1/8in (3mm) thick. It's 2in wide, so will have to be cut lengthwise. Hopefully 30ft will be enough...good grief. Maybe we should do a group buy :D
  • pitdogg2pitdogg2 Posts: 9,438
    Home depot has it in stock in the plumbing dept. if you have one close
    Ok, I guess I was looking at weather stripping. I'll check plumbing.
    Stan
    Main 2ch:
    HT:
    Other stuff:
Howdy, Stranger!
