Enya
jayman_1975
Onkyo TX NR 5008 modified by The Upgrade Company
Oppo BDP 93 modified by The Upgrade Company
Arcam CD37
Monitor Audio Gold GS 60
Revolver Audio Music 5 towers.(surround)
Vandersteen V2W
Arcam CD37
Vandersteen V2W
Gonna check this out. Used to listen to a couple of her earlier ones going to sleep.
I hadn't looked in on her for a while - this one came out in 2015 then?I disabled signatures. -
Check it out Yep2, it's a great disc.
"The Humming", "Even in the Shadows", "The forge of angels", "Echos in the Rain". My favourites. Worth a listenOnkyo TX NR 5008 modified by The Upgrade Company
Arcam CD37
Vandersteen V2W -
Let me know what you think.Onkyo TX NR 5008 modified by The Upgrade Company
Arcam CD37
Vandersteen V2W -
Definitely going to get this. Some of her recordings are better than Valium. Take you to a better place.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Thanks for the heads up. I need to take a listen.Polk S10, S8, S4
Polk RT8
Polk Monitor 7s
Working on getting SDAs -
westmassguy wrote: »Definitely going to get this. Some of her recordings are better than Valium. Take you to a better place.
I really cannot argue with you, at least on the first of your two comments
mhardy6647 wrote: »westmassguy wrote: »Definitely going to get this. Some of her recordings are better than Valium. Take you to a better place.
Perhaps not the most P.C. analogy, but you got the point.
An adult beverage, low lights, some Orinoco Flow, and my Celtic Ancestry's beast is soothed.Home Theater/2 Channel:
I enjoy some of her stuff quite a bit myself, I will confess
