New Audio Rack
[Deleted User]
I've finally reached the point that it's time to upgrade to a larger audio rack. The old one I built is completely out of room. (Yea I don't even bother feeding the cables through the center column anymore.lol)
So after stumbling across this website
http://audiofederation.com/audiophiles-guide/high-end-audio-racks I found one that I wanted to mimick.
Mine is going to be twice as beefy and will have 4 legs rather than 3. I'm going to reconfigure the program that I had for machining Larry's 1.2tl caps and make 24"x 24"x .75" aluminum shelves that'll sit on top of the spikes. After that the rest is lathe and laser work so it should go fairly fast.
Any suggestions on some add on's?
Larry has a CNC plan for the rack he built for himself that sounds like you described"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
EndersShadow wrote: »Larry has a CNC plan for the rack he built for himself that sounds like you described
Because...if I'm not mistaken... Brian and Larry work together, dipshiit! -
Im aware but it's been a few years (6 to be exact) since Larry built it so I don't know if Brian was around then....
Dill pickle sloberer....
http://forum.polkaudio.com/discussion/125475/building-my-own-audio-equipment-rack/p1
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I know where you live, Dan.....
Exciting project, Brian!
No suggestions, other than a consideration for two shorter units as opposed to one tall? Or will each 'shelf' be modular and able to be stacked in any configuration? I'll be following along on this one. You fab guys make me jealous!
Noticed some interesting bits in/on your turntable. Care to detail on this or another thread?I disabled signatures. -
Brad Pit says Rule #1 we don't talk about Turntables...
Two suggestions. One, get rid of that Monster power conditioner and two, don't paint the rack red.Political Correctness'.........defined
President of Club Polk -
A challenge would be to incorporate the drop-offs into the design.
Watching the light show from the back patio and had to chime in. Nice project....Happy 4th everyone.Don't take experimental gene therapies from known eugenicists. -
Happy 4th bro2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
You're ditching the music note symbol in the frame, right? Replacing it with something tough, like a biohazard emblem, or Tap-Out or No Fear logo?I disabled signatures.
Red is the new black.
And you know black can't be had.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Jesse Durden says Rule #1 we don't talk about Turntables...
"You are not special. You are not a beautiful and unique snowflake." - Jesse Durden; Paper St. Cable Factory, circa 2017
Nice rack! Do you have a John Travolta ghost?
That's Brad Pitt and Edward Norton..
Damn he has two celebrity ghost, nice! But we are not supposed to talk about that. -
Almost done! Im just waiting for the 1.5" round stock to come in on Wednesday. I switched from aluminum shelves to clear acrylic. It's like $250 cheaper, and far better looking.
WOW!! Stuck around a little this afternoon...
Dayam. That acrylic looks FAT! I like it! How thick are those shelves, anyway? You gonna do little edge lights in the rear to make them glow, or anything like that?I disabled signatures.
They're .75" thick.
I'm not sure yet. If I do I'd like to find a way that only illuminates the shelves and doesn't leak light anywhere else. -
Where's Brian?Yep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, modded Polk SDA 2B, Rythmik L12 sub. -
No doubt what happened?
Strange....Political Correctness'.........defined
