SRS 2.3TL
First post -- I have been reading the site for over a year. There are incredibly knowledgeable people on the site; very intimidating. I have a pair of SDA 2Bs (unmodified). I have an opportunity to buy a pair of SRS 2.3TLs. I would like to do all the necessary mods using the information available on this site. I figure that if I'm going to do all the mods it makes more sense to step up to the SRS 2.3s. Am I on the right track?
Best Answers
Answers
  • Thanks for the input. Hopefully I can pick them up this weekend!!
  • My First post as well...Happened to check the local kijiji and came across a pair of SRS 2.3TL's for $200 Canadian...which is what about 160 USD!!. Had to replace a couple of the midrange drivers but what a steal easily the best speakers Ive ever had. No mods as of yet but a recap is in the future plans.
    Andrew
    Kamloops, BC, Canada
  • pitdogg2pitdogg2 Posts: 9,436
    Nikonboy wrote: »
    Andrew
    Pictures or it didn't happen is the rule here
    Welcome to club Polk
  • machonemachone Posts: 916
    I love mine. They are great speakers. Go get them.
    Mojo Audio Joule v5>>Quantum Byte w/JRiver 21 and Fidelizer>> Starlight 7 USB >> Marantz SA 8005>> Equinox 7>>
    ModWright SWL 9.0 SE Signature >>Equinox 7>>
    Hafler DH-500 Amp+ (Musical Concepts PA-6 Elite Mod) >>Belden 5000 10 ga cables>>
    SRS 2.3TL (Fully Modified)...SDA-1A (Fully Modified with Dimensional Tweeter Delete)
    1KVA Dreadnought
  • tonybtonyb Posts: 28,721
    The 2.3 tl's are probably one of Polk's best speakers they ever put out. Like John said, once upgraded, you'd be hard pressed to do better for the money. Grab 'em, update 'em, and enjoy.
    Sony BRP
    Tad bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
  • monepolkmonepolk Posts: 798
    Nikonboy wrote: »
    Andrew
    Congrats and welcome to the forum.
  • What would be the first and least expensive mod to do ?
    Thanks in advance
    Andrew
  • dkfreebirddkfreebird Posts: 1,013
    Reseal the cabinets if needed,glue the magnets and dynamat the baskets.
    Polk 1.2tl's Fully modded with dreadnought.2.3tl's and 3.1tl's
    McCormack DNA 0.5 Deluxe
    Rogue Magnum 66
    Marantz HD-DAC 1
    Marantz UD 7007
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Home theater
    Marantz SR 5009 Sunfire Signature 425x5-B&W Cdm1nt Cdm Center Channel-Rel Strata iii sub
  • Thank you dkfreebird!! Specifically which type of glue and are there any images on the site to follow.
    Cheers
    Loctite power grab and if you search 2.3tl upgrades you should see several posts on them.
    Rogue Magnum 66
    Marantz HD-DAC 1
    Marantz UD 7007
    Pangea PC
    Home theater
  • Viking64Viking64 Posts: 2,193
    SDA's of this size are supposed to be 3 feet from the outside walls. Although I can't see much of the wall behind your gear and just how long it is, it would probably help a lot if you shifted things to the right a bit. Perhaps switching the right cabinet and the subwoofer.
    I used Loctite brand PowerGrab Express as it can be used for both sealing the cabinets and gluing the driver magnets. Two tubes should be more than enough. You should get the 6oz squeeze tube as opposed to the 9oz tube that is used with a caulk gun because there are so many nooks and crannies you'll need to get inside the cabinet where a caulk gun won't fit.
    https://www.homedepot.com/p/Loctite-6-fl-oz-Power-Grab-Express-All-Purpose-Construction-Adhesive-Squeeze-Tube-2029846/206432100
  • Yea unfortunatly this placement is temporary Im building an AV room upstairs in the attic but again won't have the space to do the 3 foot spacing from the walls and 6-8 feet between the speakers; the new AV room is 11X22. They still sound amazing as is but I will switch around the subwoofer and I am presently running a Yamaha M4 amp with an Anthem Tube Pre amp (PRE2L). I'll check the local home depot they should have that brand. Thanks to all for the information what a great resource.
    Andrew
    From the images where exactly am I installing the glue?
    Andrew
  • NikonboyNikonboy Posts: 13
    edited November 2017
  • Ha Im have trouble loading images !!
    Where the magnet meets the metal.
    Rogue Magnum 66
    Marantz HD-DAC 1
    Marantz UD 7007
    Pangea PC
    Home theater
    Nikonboy wrote: »
    Yeah, the site was acting weird for a few minutes. I shopped one of your images but I couldn't upload it. :p
  • Thanks again guys its now of course obvious where the glue has to go...
    Andrew
    Dynamat extream the baskets while out.
    Rabbit is fully opened
Howdy, Stranger!
