speaker location - front ported speakers - wall distance
Just trying to figure out speaker locations for a new set of speakers. So am I correct in assuming that front ported speakers aren't as affected by their exact location to the rear wall as rear ported speakers? Or will the speakers get a bit more 'boomy" the closer to the wall they are?
I know I can move them, but they are awfully heavy..... Maybe 60 - 70 pounds each. Making spikes for the stands, then I'll refine the speaker location.
you have a manual for those, it may tell you the recommended distance from the walls. but personally i would just move them around till you get the spot that sounds best to you.
you are correct front ported should not matter "as much". but it may still need some space.Cambridge Azur 651A
Polk LSi M703
Sonos Connect -
I would bring them forward a bit so the front of the speakers is even with or an inch or two in front of the rack. Distance from the front wall should not be an issue with those speakers in that location. Toe them in so they are pointed at your shoulders in your seated area. If you can, set the speakers so your seated position and the speakers form roughly an equal triangle. The tweeters should be even with your ears as close as possible. Could be a shorter stand may work better for that since the tweeters are high mounted on the speakers?
I found running front ported speakers pretty close to the rear wall to have little impact on them.
Corner loading them, or one of them can impact them though. -
Upstatemax : corner loading means getting them too close to the corner of a room, right?
Objects (racks etc) in between the speakers will deteriorate the stereo image (sound stage)
Front of speakers should clear rack by at leat 2-4".
Height is another tweak, along with toe-in and width between speakers
6'-8' is a start, some masking tape is useful to mark
Those speakers should and are capable of producing a nice sound stage, which is a 3-dimensional effect like the band is on stage.
Corner loading is a term for bass response, by using the corners of the room to create more resonance but to much can cause a bloated bass effect.
It's all about dialing in a system to whats best to your ears, and what genres of music you listen too.
It's hard to say "too" close. Getting them in the corner might help with bass response and a better balance. But it can also lead to bloated bass and loss of a balanced response.
It's all dependent on the room, speaker and your preferences...
As txcoastal1 said, it's all about dialing it to what's best for your ears.
Is your right speaker near a corner too, like the left?
When you are boxed by corners close to sidewalls, first reflection points on sidewall can obscure the stereo image, narrow the sound stage. Acoustic treatments will help prevent that.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Putting the speakers on spikes right now. Will take a photo in a few minutes of where the speakers are sitting. From the installation instructions, the speakers should be 3/4 of the distance apart from the sitting area.... So in my case, the speakers should be about 7.5 feet apart, as the listening distance is about 10'. Trying to slowly dial it in.
Also on the height of your speaker and listening chair or sofa
Your sound will most likely be best heard with ears between the red lines...and yes the sweet spot gets better by every inch, but of course not everyone can sit in the "sweetest spot"
TX Coastal: sounds like I need a minimal rack as well. I think what I have is too big...
Just bring the speakers a little forward, if you have kids family running through the room move them back
When no buddies around move them to the sweet spot and enjoy....no rules here2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
I have them about a foot from the wall. 1.5 to 2 feet is likely better?
TXCoasal: luckily, the tweeter height is just right for the couch. I think I'll need to get the speakers a bit closer together, and get a smaller stereo cabinet..... Still trying to decide if I want to keep a CD player, or go for a good computer / DAC setup.....
You can best start of with an equilateral triangle by toeing in the speakers. Get a folding chair to move around in your listening position. Might not be the best for every day life style, but most of us take advantage when just hanging out and family is away.
Your just looking for the sweet spot, which is likely where the edge of the table is just in front of your couch, with a little more toe in.
But this all varies, and like I said may not be practical for daily use, but fun when you can do it.
@jolson72 - You may find the following information useful:
http://www.myspeakersetup.com/
https://youtu.be/84Pf0ycbyBMAudio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
That's a tough room to work with because of the opening in the wall unless there is a door there that can be closed. Or, can the system be moved to the opposite end of the room? I suspect the way it's set up now a good balance will be difficult to achieve for two channel stereo.
That's a cool room, but man is that a tough one to work with. You're couch is way too far away for one. I would tear everything down, and situate the speakers on either side of the fire place, and put the equipment rack off to the side. A friend of mine does this, and it works out very nice.
I would think that door way is sucking out your soundstage? I've had the displeasure of working with some tricky rooms, but in the end, and after a lot of buggering around, I figured things out.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
i would try to get that speaker cable laying flat on the ground.. the way its hanging off that speaker i see someone stepping on it at some point and knocking over the speaker..
yes the couch looks too far away.. generally if the speakers are 10 feet apart you want to have the couch about 10 feet away from the speakers. each line in the tangle should be the same length..
Cambridge Azur 651A
Polk LSi M703
Sonos Connect -
Yes, the speaker cables are temporary. Trying to figure out the best location, first. Then I might drill through the floor so they can be below the carpet. Still moving, trying to figure out the best location.
Part of my thoughts on my current speaker / stereo placement is the long room that I have to work with. Probably 15 feet wide and 40 feet long. Here is a photo. I'd get better sound if I had the stereo on the wall with the fireplace, most likely?
The photo shows the room. You can see the chair at the bottom of the photo,
which is where the dining room table is. Again, I appreciate all the help:
Good thoughts and GREAT room.
Following w/ interest... -
Looks like you have a good spot on left side of the room. Move the LP' s to where stereo is now. What I do not know is whether or not you have an outlet there.
Things would be so much easier for audio if fireplaces did not exist in living rooms.
I agree, if there is enough room to the left of the fireplace that may be the best location. -
thanks for the continued help. another question: having the stereo facing a big bank of windows.... Is that bad for the sound, or too hard / harsh? Here are a few more photos. Most people seem to think I should put my system near the fireplace. It would face the windows, with the listening area being a couch sitting near the windows. Thoughts?
You would want to put some curtains up on the windows and close them when listening to music. Looks to me like it is best to have the speakers flanking the fireplace given there is not enough room to the left and there is another doorway there.
Emlyn: thanks for the help. I am not interested in curtains, or going to that level for sound. Is the fireplace still my best option? Makes speaker cable / stereo placement difficult as well, however.... Always some sort of difficulty....
I agree, there's not really an ideal audio choice in that room and it is a good looking window. You appear to have a really nice LP collection, so a turntable is necessary there which means a two channel system instead of a single wireless streaming speaker set up some people have moved to. Since everything is already set up where it's at now, I'd stick with it for a while with minor tweaks. To answer your original question though, you would just need to move the speakers out a little bit from the front wall and make them equal distance and toe in from each side wall.
I like the Mid Century Modern influence.
2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
The best way to predict the future is to invent it.
It is imperative that we recognize that an opinion is not a fact.
Imagine making politics your entire personality.
