New caps and resistors for vintage monitor 10a please help
Hi y'all, where do I go to buy the caps and resistors for my vintage monitor 10a? I want sonicap caps and mills resistors. For the caps, I went to "sonic craft" they had some sonicap caps but not in the values I needed. Also, do I want gen 1, gen 2 or platinum? For the resistors I went to parts express and parts connexion but again, they had some mills resistors, but not in the values that I need. Finally, am I correct in what I need: a 2.5 ohm 5 watt resistor, a 2.7 ohm 5 watt resistor, two 12 uF caps and a 34 uF cap? Thanks
Music Hall MMF-2.2 > Musical Fidelity V-LPS 2 or NAD C 516BEE > Emotiva XSP-1 G2 > Emotiva UPA-1 (x2) > vintage Polk Audio monitor 7c TL modded w/ Sonicaps and mills & RD0-198’s
  • motorhead43026
    motorhead43026 Posts: 3,892
    edited June 2017
    Sonicraft has those exact values.
    http://soniccraft.com/
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    The best way to predict the future is to invent it.
    It is imperative that we recognize that an opinion is not a fact.
    Imagine making politics your entire personality.
  • MrBlackCrow
    Ok, yes I apologize, I see now that sonicraft has the sonicap gen 1 in those vales. Now, They have the 2.5 ohm 5 watt mills resistor but not the 2.7 ohm 5 watt resistor that I can see. Still need someone to chime in and tell me if those indeed are the correct values that I need for monitor 10a. Thanks
  • MrBlackCrow
    Actually, parts connexion may have the mills resistors, it was just difficult to read the values at first- they have them coded with letters. I may call Polk and see if they can tell me the correct values for these things I need.
  • westmassguy
    westmassguy Posts: 6,850
    You can use the 10 or 12 watt Mills or Vishay/Mills. Both are better than the 5 watt sandcast resistors you have now
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • FestYboy
    FestYboy Posts: 3,861
    There's a stickie at the top of this section that should give you the values that you need. Courtesy of Polk Audio.
  • MrBlackCrow
    Thanks, I just looked inside and they are indeed all the values that I thought they were. Though, I was told I would have to be creative fitting the sonicaps in there because they are much bigger than the originals. I wonder if there are any relatively good caps nowadays that are smaller, that would fit better?
    F1nut Posts: 49,794
    No.
  • motorhead43026
    If you are not going to spend the money to do them right, don't bother.
  • Faustin
    Faustin Posts: 1,149
    You can pick up a little bit of room if you mount the resistors on the bottom of the board. You may have to get a little creative.04ushpfonn7f.jpg
  • MrBlackCrow
    Ok, I'll go with the good sonicaps and make them fit somehow.
  • skrol
    skrol Posts: 3,337
    To get mine to fit in the RTA11TLs, I had to assemble the PC board to the terminal cup inside the cabinet.
    Stan
    Main 2ch:
    HT:
    Other stuff:
