What do I need to drive Sennheiser 650's?
afterburntafterburnt Posts: 3,458
I imagine that my P5 will run them but will my iFi Nano?
Parlor: Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
Dungeon: Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*Usher N-6361*Wireworld Oasis cables*Wireworld Oasis IC's*IFI nano IDSD* Cambridge CXU*
Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
Hello Kitty boombox
Spares: Yamaha RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*Samsung BD-H5900 3D Blu-Ray*
Self Control is over rated.
  • BlueFoxBlueFox Posts: 9,529
    Try it and find out. I run mine off a Benchmark DAC.
    Bud
    Lumin S1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
    Shunyata Triton v3/Typhon for source, Denali 2000 (2) for amps
    Shunyata Z Anaconda XLR analog ICs, Z Anaconda speaker cables
  • txcoastal1txcoastal1 Posts: 8,655
    I think it will be fine
    2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures, Simaudio 780D DAC
    Gear on standby: Melody 101 tube pre, Modwright LS100, Unison Research Simply Italy Integrated
    Gone to new homes: (Matt Polk's)Threshold Stasis SA12e monoblocks, Pass XA30.5 amp, Usher MD2 speakers, Dynaudio C4 platinum speakers
  • mrbironmrbiron Posts: 4,558
    I'll be using my BH Crack *snicker* :p
    Zu Audio Omen MK-1B's, Peachtree Decco65, Bryston BDA-2, Cheap TT, PS Audio UPC200, PS Audio AC3's, Zu Mission SC's, HTPC, One, Bottlehead Reduction & Crack w/Speedball
  • BH Crack + 650s -- a great combination, to be sure. But you can get very close to that with a Schiit Vali 2. Replace the stock tube (which is pretty good) with RCA 6CG7 (plentiful on eBay) and you'll get a big, warm, full sound thru the 650s. If you like razor-sharp analytical sound, this isn't for you. But works for me!
  • ZLTFULZLTFUL Posts: 4,228
    I run a Little Dot I+ for my AKGs...going to try the same amp with my new HD558s. My first pair of Senns though...
    2 Channel: Silverline Audio Sonatina MKI, Monitor 5 Series II, DIY Seas based bookies
    LR 2 Channel: LSi7, DSW-MP2000
    HT: JTR Triple 8 LCRs, DIYSG Volt 8LX Surrounds, DIYSG Volt 6LX Atmos, 6 SI HT-18D2 Subs
    Guest BR 2 Channel: Swans D1080MKII
    Deck: Pyle BT Speaker pair with upgraded woofers
  • EmlynEmlyn Posts: 1,945
    Either source would work. However, the 650s are 300 ohm headphones and your 598s are 50 ohm. The 650s may not go as loud as the 598s, or they may. Only way to see for sure if the volume and sound quality is what you are looking for is to try them with your sources. Most of the concern with the 650s or 600s is using them with portable battery powered devices. Since they are both open backed headphones, I have never used mine outside the house anyway so use with portable devices has been a non issue for me. They perform best with a dedicated headphone amp of course.
    1. Polk LSiM707, 704C, 703; Dual SVS SB2000 subwoofers; Marantz SR7011 receiver; Parasound A23 amp; Oppo 205; Toshiba HD-DVD Player; Sony 65" 4K TV; FIOS; PS Audio Power Plant Premier; MIT S2 cables
    2. JM Labs Electra 920.1; Parasound JC2 Preamp; Parasound A21; Sony HAP-Z1ES; Oppo 105D; Music Hall MMF7 and Acoustech phono pre; PS Audio P1000; MIT S1 Cables
    3. Polk LSiM703; Pioneer Elite SC97 receiver; Oppo 203; Squeezebox Touch; MIT S3 cables
Howdy, Stranger!
