Anyone try these replacement pads?
afterburntafterburnt Posts: 4,053
Parlor: ifi iDSD Micro*Yamaha RX-A2030*Parasound Halo P5*Parasound Halo A-31*Parasound 2250v2*Emotiva XPA-200 Gen1*LSiM707 Fronts*LSiM706c Center*LSiM702f/x Surrounds*Monitor70 Series II Rears*Monitor40 Series II Presence*SVS PB2000 Sub X2*OPPO BDP-103D*Sony PS3*Samsung-55" LED 1080p Smart 3D HDTV UN55H7150AFXZA*TEAC TN-300*Wireworld Solstice cables* Wireworld Stratus power cables*Blue Jeans Cable LC-1's IC's*BJC Silver-Plated IC's* Bens Silver IC's
Dungeon: Dancer Mini-Two Diamond*Auralic Aries Mini*Dayens Ampino Preamp*Dayens Ampino Monoblocks*North Star Intenso DAC*Wireworld Oasis cables*Wireworld Oasis IC's*Wireworld Aurora power cables*IFI nano IDSD bl*Pangea Silver USB*Cambridge CXU*
Panamax MR5100*Panamax M8-AV-PRO*Furman PST-2+6
Headgear: Sennheiser HD 558*Audio-Technica ATH-M40x*Sennheiser HD 598 Cs*Audio-Technica ATH-MSR7*Philips SHP9500S* Sennheiser 6xx
Hello Kitty boombox
Spare sortta: ifi iDsd nano*Marantz 1504* RX-A1040*Emotiva XPA-1L Gen2 X2*Emotiva XPA-3 Gen2*CSiA6 Center*Monitor40 Series II*SVS PB1000 Sub*Sony BDPS6500 Blu-ray player*POS 37" LCD*Douglas Connection Furez 12 AWG 2 Conductor*Blue Jeans Cable LC-1's IC's*Samsung BD-H5900 3D Blu-Ray*Usher N-6361
Self Control is over rated.
Mr. Sharpe wrote: »
Meh these were extra $70 as an open box item so it didn’t much to me either way:)
  • afterburntafterburnt Posts: 4,053
    Are cans designed to be on ear ya know etc?
    Hello Kitty boombox
    Mr. Sharpe wrote: »
    Probly wont fit ATH40X
    Hello Kitty boombox
    Mr. Sharpe wrote: »
    I should buy 50's to see how they work
    Hello Kitty boombox
    Mr. Sharpe wrote: »
  • aprazer402aprazer402 Posts: 928
    Have not tried those. Some aftermarket replacement pads will definitely change the sound of the headphones. Headphones are designed and tuned with the ear pads they originally came with. Thicker (intending to be more comfortable) pads might change their sound. Be sure to read several reviews of the replacement pads especially for a higher-end set of cans.
    edited June 2017
    Hello Kitty boombox
    Mr. Sharpe wrote: »
    aprazer402 wrote: »
    40cs are not too expensive cans and I like the sound. Probably better to get better cans.
    Hello Kitty boombox
    Mr. Sharpe wrote: »
  • skrolskrol Posts: 2,615
    I had replaced my Grado 225i L-cushion pads with some from Ear Zonk from Amazon and am very pleased, especially at half the price and they came with a headphone case for the Grados that works great.
    Stan
    Main 2ch:
    Polk LSi15 (DB840 upgrade), Parasound: P/LD-1100, HCA-1000A; Denon: DVD-2910, DRM-800A; Monster HTS3600-MKII, Grado SR-225i
    HT:
    Denon AVR-888, Polk: RTA11TL (RDO198-1, XO and Damping Upgrades), S4, CS250, PSW10, Marantz UD5005, Panasonic TC-P42S60
    Other stuff:
    Denon: DRA-835R, DCD-660, DRM-700A, DRR-780; Polk: S8, Monitor 5A, TSi100; Pioneer: CT-6R, PL-530; Onkyo CP-1046F; Ortofon OM5E, Marantz: PM5004, CD5004, Polk: RM7, Parasound C/PT-600, HCA-800ii
  • agfrostagfrost Posts: 2,090
    The first pair of pads you posted are ones I intend to try with my Massdrop/HifiManHE350 headphones. Others have tried them with those hp and report good results.
    I agree with aprazer's comment re changing the sound--it could be a good thing, or perhaps not. Moreover, those Brainwavz pads are for over-ear hp and may not be a fit for your on-ears.
    Good luck!
    Jay
    SDA 2BTL * Musical Fidelity A5cr amp * Marantz DV-9500 * Modded Adcom GDA-600 DAC * Rythmik F8
    Micro Seiki DQ-50 * A hodgepodge of cabling * Belkin PF60
Howdy, Stranger!
