Polk Surroundbar 4000 - No remote function
My Polk Surroundbar 4000 does not receive the signals from the remote, either the included remote or any remote that I have tried to use with the learn function. Does anyone know exactly where the receiver is located?
  • KennethSwaugerKennethSwauger Moderator Posts: 6,370
    Hello,
    Welcome to Polk's forum, I'm sorry there's a problem with the 4000's remote. I don't know precisely where the remote receiver is located, but usually it is in the center of the front grille area near the bottom. I would recommend giving Polk's CS department a call on Monday at 1-800-377-7655 select option 1 and they'll help you get things working.
    Regards, Ken
    "And the house you live in will never fall down
    If you pity the stranger who stands at your gate" G.Lightfoot
Howdy, Stranger!
