Active speaker recommendations for amazon echo dot?
packetjones
Hello everyone. Been a little while since i have posted anything but thought i would stop in and ask for some recommendations. I have an echo dot in my kitchen connected to some old cheap computer speakers. I am looking to update these speakers and was curious what others would choose in my position.
I am looking to spend no more than $200. I would like powered speakers since it is on the cabinet in my kitchen and i would not like a separate amp on the counter. I think that spending more than this on powered speakers is a little silly and even $200 seems a lot to me for speakers used when cooking dinner. I know that i could go with passive speakers and get a better overall speaker, but it is what it is.
I am looking at the following companies and was wondering if anyone had experience with them or could recommend others to check out. I see the AudioEngine, Edifier, Mica, and Swans. Anything else out there i should be looking at before i make a decision?
Thanks for any recommendations.
Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110
Rear - RTiA3's
Center - CSiA4
Sub - PSW110
https://www.amazon.com/Audioengine-A2-Powered-Speaker-System/dp/B00DQMJE7E/ref=sr_1_1?ie=UTF8&qid=1497623569&sr=8-1&keywords=audioengine+a2
And done.
Arguably one of the best small footprint active speakers available. I was going to get the same ones in white for my guest bedroom to run with an Echo Dot as well."Some people find it easier to be conceited rather than correct."
