Woot!!! Finally a SDA owner
Just picked up a pair of CRS.
Only issue is no interconnect cable (dual blade type). From the schematics listed here, it's a '85ish model? I'll be making an IC cable with a Speakon, but I'm a bit confused about the pin outs for it. The schematic only shows one channel and it's unclear if the pins cross or stay in orientation from side to side, and then I've read that only one pin is actually active?
Looking for a little more clarification please.
    pitdogg2 Posts: 24,577
    Blade/blade are both active. Do you know what drivers are in them? Seeing that they have dual tweeters both blades will be carring signal.
    The switch is inside the cabinet. Get good pictures of the wire orientation before you do anything. Each speaker is the opposite of the other so do not tear down both at same time or you could confuse yourself.
  • FestYboy
    FestYboy Posts: 3,861
    Good to know. I'll pull one apart and post the driver #s. I'm also wondering if this should go 194, or 198? So far as I can tell, they have the SL2K tweets.
    FestYboy wrote: »
    194's
  • westmassguy
    westmassguy Posts: 6,850
    RD-0194s are drop-in replacements. Once you get the IC squared away, try operating them with the dimensional tweeters disconnected. You may like it better.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • FestYboy
    You mean just the tweeters out of circuit? I always wondered why the next gen of CRS and some SDA2s only had the one tweet.
  • westmassguy
    Polk eliminated the dimensional tweeters after the 2nd generation. The outer tweeters are the ones to disconnect.
  • machone
    machone Posts: 1,475
    Congrats on the SDAs.
    I disconnected the SDA tweeters on my 1A's and like it better.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • [Deleted User]
    [Deleted User] Posts: 10,716
    Great pickup! I'm still on the lookout :)
  • Drahthaar
    Drahthaar Posts: 48
    Congrats, I picked up a pair about a year ago and love them. I also unhooked the SDA tweeter and cut out some of the harshness of the tweeters
  • FestYboy
    I'm hoping the swap to the 194s will help in that department. If I feel that the secondary tweeter still needs to go, then I'll have an extra pair for another project ;) and the 2000s will fill the void.
  • machone
    Another advantage in not using the SDA tweeters is when you upgrade the x-overs there's half the tweeter circuit parts required.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • voltz
    voltz Posts: 5,384
    Congrats on the CRS's :)
  • VSAT88
    VSAT88 Posts: 1,227
    Been wanting a pair of CRS's for a while. Good deal, you got some !
  • FestYboy
    I'll put it out there, voltz is the man! Hooked me up sumpin fierce! Can't wait to get these things fired up as they were meant to be.
  • FestYboy
    Ok, so after a generational snafu, voltz it STILL the man.... I'll just have to wait a little longer to get them doing the voodoo that they do so well.
  • MrBuhl
    MrBuhl Posts: 2,419
    congrats - CRS are one of the ones I've yet to hear/try, but they are high on the list!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
