There's a thing in my house
-- a new-to-me thing.
It's very, very dense.
Very.
Dense.
Here is a bottom view.
34211237723_4c0a931f26_b.jpgDSC_8306 by Mark Hardy, on Flickr
and a bottom/side view.
34858131692_94b2a5e46d_b.jpgDSC_8309 by Mark Hardy, on Flickr
Further details as events warrant.
It'll be a while -- this is a project*.
* Not a Pro-Ject (just to be clear).
"It's like watching a roomful of people who couldn't get through college algebra discussing the flaws of quantum physics theory. I guess it could be fun, but it's ultimately a waste of time." -- seen on audiokarma
"Some amps run on self bias, some amps run on fixed bias. But his amps run on confirmation bias." -- seen on audioasylum
"Writing about hifi is like dancing about architecture" -- paraphrasing some wag (possibly Frank Zappa)
  • msgmsg Posts: 3,971
    Ahhh, COME on!!!
  • kharp1kharp1 Posts: 2,235
    YOU TEASE!
    Main System:
    Joule-Electra LA 100 MKIII
    Pass Labs Aleph 30, McCormack DNA-125, Parasound A21
    Marantz SA-14S1
    Usher CP-6311/Tyler Acoustics Taylo Reference Monitor, LSA-1
    Dual SVS SB2000
    Wireworld Equinox 7 bi-wire, Wireworld Silver Eclipse 7 IC
    Secondary Rig:
    Parasound P5, Audio Electronics by Cary Constellation
    Marsh a200s, Audio Elecrtonics by Cary Hercules
    Pioneer Elite DV-45a, Denon DVD-2910
    Klipsch Epic CF-1, Vandersteen 3CE sig
    Analysus Plus Oval
  • voltzvoltz Posts: 4,922
    DOC there is a nasty little spider near your Spider!
  • mhardy6647mhardy6647 Posts: 17,358
    yes, the arachnid-type spider has been -- dealt with.
  • DSkipDSkip Posts: 14,408
    Made in Italy. Me likey already.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
  • BlueFoxBlueFox Posts: 9,877
    Doesn't look like a DAC to me. :)
    Bud
    Lumin S1
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
    Shunyata Triton v3/Typhon for source, Denali 2000 (2) for amps
    edited May 2017
    BlueFox wrote: »
    Verily.
    (I need to post an "in use" DAC photo -- it's been a little nutty 'round the ol' Hardy household latterly)
  • nbrowsernbrowser Posts: 7,914
    edited May 2017
    Best Guess...
    http://sica.it/en/products.html?page=shop.browse&category_id=8&parentCategory=1
    Last one listed, the 8 inch version. Or possibly 10 inch.
    Living room: Samsung UN55KU7000 4K UHD HDR 55 inch TV, Marantz CD6004, Pro-Ject Debut Carbon, Parasound zPhono, Mac Mini, Oppo BDP-93, XBox One S 2Tb, Kenwood DPX792BH car deck for radio purposes, Marantz SR5010 AVR, Parasound HCA-1200II, Front SDA 2 modded with Larrys Rings and RD0-194-1 tweeters, Rear Onkyo SKF-4800 Towers, Center CSiA6, BOOM Tannoy TS2.12 Sub, Audioquest Evergreen interconnects just about everywhere except from AVR to amp, MIT Terminator 4, MIT AVT3 speaker cables with extra terminals covered up Monitor 5 Jr+ in the wings for a center channel.
    bigger.
    and there are two of them.
    in one box.
    one very dense box.
    Dual 12 inch coaxes in one box? Cripes...I was thinkin ten inch at most...but a dozen inches....sweet! (Apologies, I like a bit of detective work!)
  • First!
    (in line to buy the Doc Hardy speakers) :D
    Studio 2 equipment;
    Yamaha a-s2100 Amp, CD-2100 CD player, T-S500 tuner
    Loudspeakers: Harbeth p3esr, Polk RT7
    Cables: Aural Harmony Sonnet Interconnect II, WireWorld Equinox 7 speaker,
    Black Cat silverstar 75 ohm digital, Signal Digital Power Cord, PS Audio Perfect Wave AC-3,
    Pangea SE14, Voltz supplied interconnects
    Optional: Arcam DV88 DVD/CD (HDCD) player, Polk SDS-400 speakers
  • mrbironmrbiron Posts: 4,693
    Hmmm...it's a speaker....screwed to a piece of pine....with a DENSE 10lb rock on it for stabilization.
    What is lemon zester!
    Zu Audio Omen MK-1B's, Peachtree Decco65, Bryston BDA-2, Cheap TT, PS Audio UPC200, PS Audio AC3's, Zu Mission SC's, HTPC, One, Bottlehead Reduction & Crack w/Speedball
  • BlueMDPickerBlueMDPicker Old Polk Posts: 6,948
    Butt shakers for the front porch swing? Tractor speakers? Brown sound generator?
    nbrowser wrote: »
    Bigger. :)
    Based on appearances, I would think this thing is brown-note-compliant.
    Oh, and mrbiron, it is (to the best of my knowledge) 100% rock free.
    mrbiron wrote: »
    it not a rock on it, it is ;) a certain phono amp
    Much work remains to be done -- right now, we're looking at two beefy 15" dual VC drivers mounted in an -- interesting -- configuration in a massive MDF prototype box.
    ... but the thing certainly looks purposeful; I have to think it will be good for something, audio-wise.
  • FTGVFTGV Posts: 3,544
    edited June 2017
    Looks like bottom woofer is slot loaded with the floor or a bottom panel?
    The bottom woofer fires "up" into the sealed enclosure (it's back side hangs out in the breeze, as the photo shows, albeit none too clearly).
    The other woofer fires "out" of the front of the enclosure. You'll have to take my word for now; it's too danged heavy to drag out of its current (temporary) resting place :)
    So then its push pull with bottom woofer slot loaded.Should dig deep.
Howdy, Stranger!
