can I connect an SR2 to the network and listen to the AUX-IN connected to a SB1 in the same group?
buckettea
I'm obviously lacking a bit of knowledge and/or components here...
If I have an output of my Blueray (for example) connected to the AUX-IN on my SB1, is there any way to get the same audio delivered to an SR2 on the same network, over the wifi without additional devices?
I'm trying to setup a theatre, I have a pay-tv STB with an analogue audio out. It is connected to the SB1 AUX-IN. I have just purchased an SR2 thinking I could 'group' those speakers together and have the same audio on both the SR2 and SB1 coming from that AUX-IN input.
i have not found a way... is there one?
Best Answer
This will, in the future, be something possible, but not at present. The SB1+ has the ability to re stream content from a line in, but it is currently not enabled. This feature was disabled to allow the system to have rear surrounds. At this time there isn't a definitive date as to when this will change. As more specific information becomes available Polk Audio will make it available.
Best regards, Ken
Answers
I'll check for you.
thanks Ken for your efforts!
does seem a shame to disable a feature, rather than have the user decide which one they want to use... easier to accept you can't have both. i guess the lesson here is don't listen to the sales people
