I'd like to install a pair of Polk 14 speakers on the Optical Digital Audio Out of my LG6090. I need
an idea for in inexpensive amp that will receive (accept ) the cable with subsequent connection to the speakers. Is there another way to do this. The speakers are 20 watts (2) I believe. I've read about a Digital optical c oAxial Toslink Signal to an Analog Audio Converter .I know this is a cheapee but I've got only one ear and my wife has hearing aids. I'm just trying to hear the shows w/o investing $100's or $1000's
Answers
  • txcoastal1txcoastal1 Posts: 9,509
    Look at Peach Tree audio products
    2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures, Simaudio 780D DAC
    Gear on standby: Melody 101 tube pre, Modwright LS100, Unison Research Simply Italy Integrated
    Gone to new homes: (Matt Polk's)Threshold Stasis SA12e monoblocks, Pass XA30.5 amp, Usher MD2 speakers, Dynaudio C4 platinum speakers
  • Jim ShearerJim Shearer Posts: 350
    Since you want the cheapest means to get optical from your TV to a pair of speakers, and aren't concerned with high sound quality, here is one possibility:
    optical converter:
    https://www.parts-express.com/fiio-d03k-coaxial-optical-dac-digital-analog-converter--230-120
    small amp--if 8 wpc into 8 ohms is sufficient:
    https://www.parts-express.com/dayton-audio-dta3116s-class-d-micro-mini-amplifier-2-x-15w--300-3815
    if you need more power, then consider:
    https://www.parts-express.com/dayton-audio-dta-120-class-t-mini-amplifier-60-wpc--300-3800
    Note: both amps use class-T (sub set of class-D) topology, and as such are not compatible with sub-woofers using speaker level connections!
    Best thing to do may be to call Parts Express & talk with one of their advisors to make sure this would work!
    Cheers, Jim
    A day without music is like a day without food.
  • tonybtonyb Posts: 28,935
    Cheapest way in my view, grab a receiver off of craigslist that has digital inputs. You can usually find one for 25-50 bucks. Connect the digital output of the tv to the digital input of the receiver, then connect the speakers to the receiver and your done.
    Sony BRP
    Tad bookies
    Polk 500 surrounds
    Polk s35 center
    Sonos
    Music-
    Joule la-100 pre
    B&k 1403 amp
    Cary xciter dac
    Cullen modded Sonos
    ERA D5 bookies
    Analysis plus crystal oval ic's
  • deronb1deronb1 Posts: 4,190
    tonyb wrote: »
    Yup, and if you are not comfortable wuth CL, pawn shops and some check cashing places usually have oodles of em.
Howdy, Stranger!
