A Marantz Question
mrlorenmrloren Posts: 1,313
Happy Saturday :)
I have a question for Marantz owners.
I have come to find after 6 months of ownership that there is 3 different ways to adjust the sub level on my SR5010
1 go into "speakers" and manual level control and change it there
2 go into "Audio" and select Subwoofer Level Adjust, turn it to on and move it up or down.
Adjusting the sub on either of these makes a little difference
3 press the options button and adjust the sub level there. This seems to have the biggest affect on over sound quality. #1 & #2 adjustments make the sub more localized #3 seems to increase overall bass in the system with better blending.
I had a little play time this morning so I tried each setting @ a +5db boost. 1 & 2 were localized and a little hollow. 3 was just so much nicer and fuller.
Which option do you use for adjusting your Marantz?
Family Room:
Samsung UN60H,
Marantz SR5010, Emotiva BasX-A300
Oppo BDP-93,Sony UBP-X800BM, Sony DVP-NS3100ES, WD Live HUB.
Main: Polk Signature S60
Center: Polk CSi-A6
Front High TC80i
Rear: Polk MC80
Sub: HSU VTF3-MK5
Bed Room;
Sony KDF-E42A10,
Marantz SR5010, BDP-S270
Main: Polk Signature S20
Center: Polk Signature S30
Rear: Polk R15
Sub: HSU STF-2
Working Warehouse;
Sony 2100ES
Polk RTi4 about 15' up the wall
Old sony 12" Sub
Mini tower PC with 400GB of music
  • nbrowsernbrowser Posts: 7,909
    I just use whats sounds best...or is an easier setting to get to...I'm lazy lol.
    Living room: Samsung UN55KU7000 4K UHD HDR 55 inch TV, Marantz CD6004, Pro-Ject Debut Carbon, Parasound zPhono, Mac Mini, Oppo BDP-93, XBox One S 2Tb, Kenwood DPX792BH car deck for radio purposes, Marantz SR5010 AVR, Parasound HCA-1200II, Front SDA 2 modded with Larrys Rings and RD0-194-1 tweeters, Rear Onkyo SKF-4800 Towers, Center CSiA6, BOOM Tannoy TS2.12 Sub, Audioquest Evergreen interconnects just about everywhere except from AVR to amp, MIT Terminator 4, MIT AVT3 speaker cables with extra terminals covered up Monitor 5 Jr+ in the wings for a center channel.
  • codycatalistcodycatalist Posts: 1,333
    edited May 2017
    I personally set my sub at flat on LFE or subwoofer channels, set my sub gain to half and dial it back via the same LFE settings.
    I adjust the tone via the crossover. I could imagine your speakers changing the bass tone but my sub only hits 80hz and under so it sounds like bass (unless we are talking musical vs sloppy but that doesn't seem to be your focus). No setting will make it sound better or more full without introducing more distortion. At least in my logic I've worked in my crazy head.
    Living room
    Mains: Paradigm 90P
    Lows: Velodyne CHT12, Pioneer SW-8Mk2
    Power: Marantz SR7000
    Tv: Samsung UHD 55' Curved 4k
    2 Channel Den
    Mains: SDA2B Upgraded XOs and Binding Posts
    Power: Yamaha AV34
    TT: Pioneer PL510
    Tv: Samsung UHD 55' 4K
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Little dot 1+/GE JAN 5654w
    Closet of Dreams:
    Harman Kardon AVR130
    Yamaha HTR5590
    Polk RTA11TL
    Polk TSI200s
    New Large Advents 25th Anniversary Edition
    Bravo V2/RCA Clear top Conn branded 12AU7
  • mrlorenmrloren Posts: 1,313
    The one thing I like about my Sony over the Marantz is the simple setup.
    I've ran Audyssey a few times. If I don't boost the sub up it's like it's not there. If I adjust one setting of the 3 different sub adjustments the sub get too localized. I noticed setting all 3 up a few db does the trick for some reason.
    No I don't get distortion,
    Family Room:
    Samsung UN60H,
    Center: Polk CSi-A6
    Front High TC80i
    Rear: Polk MC80
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Old sony 12" Sub
    edited June 2017
    Possibly placement? When I had my sub straight face towards me about 8 feet away I'd have to turn my gain up halfway. Moved it so it is on the left of the room facing to my right and now I can't get past 1/4 without it being too loud.
    *EDIT* Looking at your profile picture seems like you don't have much room to mess around and test placement with.
    Living room
    Mains: Paradigm 90P
    2 Channel Den
    Power: Yamaha AV34
    TT: Pioneer PL510
    Noggin Rockin'
    Phillips L2
    Grado SE80
    Harman Kardon CL
    Closet of Dreams:
    Yamaha HTR5590
    Polk RTA11TL
    Polk TSI200s
    no there is no other place to put it.. I would like to 180 the room but wife said no with an H in fronto0up4s48rvy1.jpg
    Family Room:
    Samsung UN60H,
    Center: Polk CSi-A6
    Front High TC80i
    Rear: Polk MC80
    Sub: HSU VTF3-MK5
    Bed Room;
    Sony KDF-E42A10,
    Rear: Polk R15
    Sub: HSU STF-2
    Working Warehouse;
    Sony 2100ES
    Old sony 12" Sub
  • PSOVLSKPSOVLSK Posts: 3,631
    Hno??
Howdy, Stranger!
