2nd remote sent to me and still does not work
So I'm assuming it doesn't have anything to do with the remote at this point. I tried holding down the wifi reset on back of sound bar and it did not work. Anyone have any ideas how to get my remote going?
I've been unable to adjust bass or voice for over a week.
Best Answer
  • IkeHarrisIkeHarris Posts: 6
    Accepted Answer
    Got ahold of customer service yesterday, they shipped out a complete new unit to me, will be here tomorrow.
    I have to say Polk's customer service has been excellent so far.
    Hopefully this new one will be good to go.
  • tonybtonyb Posts: 28,522
    Give Polk CS a call, they should take care of ya.
    Did you try simply unplugging the unit for about 5 minutes and plugging it back in ?
    ERA D-5
    B&K 1403
    Cary Xciter dac
    Joule LA-100
    SVS SB-2000 SUB
    Sony 4k bdp
    Sony 4k 55 850c
    FX 500 surround
    Acoustic zen Satori SC's
    Pioneer elite vsx21
    Sonos-Cullen mod.
    Audio Metallurgy GA-0 digital
    PS Audio Quintet
    Analysis Plus crystal ovals
    Acoustic zen Matrix 2's IC
    Wireworld eclipse 7 Ic's
    Thanks for the reply,
    I did do a hard reset but that didn't work.
    Unfortunately due to the holiday Polk is closed until Tuesday, I guess what's another few days after I've been waiting a few weeks already.
    Just a little aggravating having this issue only two days after purchasing....luck of the draw I suppose.
  • gimpodgimpod Posts: 1,736
    Hey @IkeHarris, If you can't get it figured out give Polk CS a call on Tuesday like @tonyb suggested.
    In the mean time a few simple things you might want to try until Tuesday,
    Don't take any of these suggestions for other than what they are as I've done them all, a couple times. :blush:
    1. Forget resetting the WiFi as it has nothing to do with the remote it's IR (Inferred).
    2. If the remote is using AAA battery's, Check that you have them installed right (some of them can be a pain to figure out what end is what +/-), Also they will most likely go in opposite directions with the negative end (-) going towards a coil spring if it has one. Also if you have a remote that uses the same battery's try swapping them.
    3. I don't know if this works with cellphone cameras or not but you might be able to see the IR pulses with the camera.
    4. Do you have something blocking the IR receiver on the front of the soundbar.
    5. Rare but I've had it happen to me, Some florescent lights will interfere with IR (Inferred signals).
    Some of these suggestion may seem condescending but there not meant to be. Sometimes the simplest thing can drive you bat poo crazy.
    Case in point back in the late 80s I spent 2 days trying to figure out why "WordPerfect" would not print lower case letters on the monitor so I called tech support and the first thing he asked was "Do you Have the Caps Lock on?", I took one look at my keyboard and I apologised to the tech for wasting his time and hung up. I really felt like the dumbest person ever born in all of human history. Something so simple I never thought of or bothered to check.
    "If you design software that any moron can use only morons will use it." JMO
    Unfortunately for most of us we only get to experience the first day and then we can't even remember it.
    "Close only counts in Horseshoes, Hand Grenades and Thermonuclear Weapons."
    "50% Why... That's almost half."
    "I know, I'm sick and need help."
    "The best way to enjoy digital music reproduction is to never listen to good analogue reproduction." ~ Kenneth Swauger
  • KennethSwaugerKennethSwauger Moderator Posts: 6,260
    I'm not sure which soundbar you have, but you might want to remove the battery and using a small screwdriver or dental pick and pull slightly on the spring contact to make sure it is making solid contact with the battery.
    "That which can be asserted without evidence, can be dismissed without evidence."
    — Christopher Hitchens
    I appreciate all the replies unfortunately I've tried pretty much all of that was suggested. I'm on my second remote now so I'm assuming it has something to do with the actual sound bar.
    It's the Magnifi mini
    I'll give them a call tomorrow again.
    Thanks again it's much appreciated
Howdy, Stranger!
