Echo Dot DAC and bluetooth
mpitogo
in Electronics
If you're into streaming from Amazon because you have prime. You maybe using an Alexa device such as the Echo or Echo Dot. I mainly use the Echo Dot. I found the Echo Dot has a poor DAC. It has a builtin 1/8" jack for analog out with "Alexa volume 10" could be considered line level. Using it this way it sounded muffled and had poor bass response. Since it had Bluetooth capabilities I read about BT audio capabilities and decided to try it out. Luckily I was passing through and saw signs of my neighborhood Radio Shack closing. I went in looking around and found they have an inexpensive BT DAC with builtin optical spdif. I gave it a try, big difference.
I have the RS BT connected to a switched outlet so is only on when I listen to music. The rest of the time it can still act as a home assistant.
The other option is using the Amazon Music App on an iOS device and using AirPlay. In my case I use it to an Airport Express with optical out.
- Living Room Music-2.0 Polk Legend L800 | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Belkin Soundform Connect | iPad Air USB to DAC
- Media Room Ht-7.2.6/13.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x4], height LSiM703 [x6], HSU VTF-15H MK2 Dual | Marantz AV8805A | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Sony UBP-X800 | AppleTV 4K | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
- Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
- Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
- Office-2.0 Ascend Acoustics Sierra LX, DSW microPRO3000 | Rotel RA-1570 | Marantz HD-CD1
- Daughter's Bedroom 1-2.0 TBD Martin Logan Forte
- Guest Room 2-2.0 Klipsch RP-600M | Martin Logan Forte
- Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
- Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Topping DX7s | Sansui FR-1080 | TV
- Maintenance: Pro-Ject VC-S Record Cleaning Machine
