Crossovers upgraded/refreshed or new integrated?
codycatalist
Not sure which I should do first.
I will be having some expendable funds coming my way in the form of $500ish. Not sure if I should get a new integrated (currently have Yamaha Av34) or if I should get my crossovers completely redone with new binding posts on my SDA 2Bs.
Help me decide.
Eventually both will be accomplished but more than likely a year or so apart.
Help me decide.
How do you like your current integrated with the speakers as they are?
If you like it, I say go crossovers first, settle into those before you make a decision on direction to head for your next front end?
Which other integrated amps would you be considering, I suppose would be the next question.I disabled signatures. -
I do like how it sounds currently, if I had to nit pick I would want more stereo separation and a warmer sound. I haven't really looked around much before as window shopping gets me in trouble. I haven't heard a ton but I do like the marantz sound and looks, old and vintage.
I know I need to look around just to even gain a good perspective of what I am looking for but I don't care about the bells and whistles. If it sounds good, looks decent, pairs good with my SDAs and is common ground I'll be happy.
I will probably end up going used for the integrated so that is not out of the question.Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
A say maybe a crossover upgrade and change the binding post to handle speakons for the inter connect cable and maybe add a Dreadnaught.2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
$change the binding post to handle speakons for the inter connect cable
$$add a Dreadnaught.
See that's 3 money signs...Wife will only allow 2 money signs. The 2 former options are more than likely the route I'll take and add a dreadnaught in the future. Beyond the old caps on the XO I feel the weakest link in the chain comes back to the integrated. That's what makes me question it a bit.
