Is this acceptable to measure inductance?
I have all the caps and resistors removed. The inductor is only attached to the board, terminal, and open wires. Will this connection throw off the reading or is it close enough within the LCR tolerance?io5h2ysal1dn.jpg
  • KennethSwaugerKennethSwauger Moderator Posts: 6,371
    That should be fine for making the measurement.
    "And the house you live in will never fall down
    If you pity the stranger who stands at your gate" G.Lightfoot
  • pkquatpkquat Posts: 543
    Thanks.
    You're welcome!
Howdy, Stranger!
