Looking for a program to transfer text messages, phone contacts, etc
michaeljhsda2
Does anyone know of a free Windows based software program that will transfer texts, phone contacts, etc from a Galaxy S4 to a Galaxy S5?
SDA SRS 2.3TL's
SDA 2B TL's
SDA 2B TL's
Have you tried the Samsung Smart Switch app? That's what I used the last two times and it worked great. Phone to phone, just hook em up;VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Thanks, I'll give that a try, however, I dropped the S4 on the floor and it's really screwed up. Only the upper portion of the display is visible and the phone is opening up all kinds of apps on it's own. I'm buying an S5 today and hopefully I'll be able to do the transfer.SDA SRS 2.3TL's
SDA 2B TL's -
Good luck! That doesn't sound so promising I'll have to agree!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
SACD Marantz DV8300
Yamaha YP-D6
Pho-700 Phono Pre
I dont know about Android, but on my windows phone, I can hop phone to phone with a cloud back up and within thirty minutesit will sync my apps, start screen layout, contacts, text messages, call history, everything. Iy is literally like I never changed phones...
I would assume Android has a similar function available- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Some you can transfer from phone to sd card then transfer back to new phone.
Just a thought
