Polk swimmer duo questions
What is the trick to keeping the speakers paired after shutdown? The variables seem to be:
What order are they turned on
What order the pair button is pressed
Which speaker is used to shutdown the pair after they are paired
At least one time when I turned them back on they paired back up automatically (I think), but how do I do this consistently?
  • [Deleted User]
    [Deleted User] Posts: 7,658
    Hello,
    Welcome to Polk's forum. The only way they would automatically reconnect is if the Swimmers were turned off then right back on within 15 seconds.
    If the Swimmers are turned off and left they will need to reconnect the speakers to each other every time.
    Regards, Ken
